G35 & G37, Coupes & Sedans
How you "safely" put your car on FOUR jackstand?
Old Jun 21, 2006 | 08:43 PM
BlackG35th's Avatar
hahaha.... sorry to jack tha thread..... trey what was ur 60 foot wen u ran that time? thats a really good time!
Old Jun 21, 2006 | 08:48 PM
aleok's Avatar
i just installed my springs and did the rear first and jacked from diff and put jack stands and car didn't roll away.
Old Jun 21, 2006 | 09:27 PM
trey.hutcheson's Avatar
See this thread for all the info(times, conditions, everything):https://g35driver.com/forums/drag/77051-13-791-102-22-a.html
Old Jun 22, 2006 | 08:33 AM
ericsherbrooke's Avatar
Originally Posted by inTgr8r
You should be doing front & rear... not side to side.
Use these lift points
I am not under my car at the moment but ...
Is it safe to use the aluminium/magnesium differential casing to support the car on the lifting jack during the leverage? Is there any "steel" braket to put the jack under? I dont beleive these "casting" are that strong...
From the past on other car I was doing "side to side" but at a certain height (around 10 inches) car wanted to slide of jack...not fun
Old Jun 22, 2006 | 08:46 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Only the diff cover is alum.
The housing is steel.
The lift points in the pic are from the manual
Old Jun 22, 2006 | 08:50 AM
InTgr8r's Avatar
Originally Posted by SkylineR35
Why not side to side? I jacked up my eclipse one side and then the other and didn't have any problems. If you jack up the rear first your car will roll away so don't do that!
Side to side there is more chance of it falling because of the shorter distance.,
& more extreme angle on the first set of jacks.
Front to rear is more stable because of the length of the wheel base.
& yes lift the front first, then the rear
Old Jun 22, 2006 | 11:08 AM
Thanks all
Old Jun 22, 2006 | 01:55 PM
PotomacG's Avatar
.... lift the front first, then the rear
Don't forget to reverse this order when putting the wheels back on the ground.
Old Jun 23, 2006 | 02:18 AM
nelam's Avatar
Go to a your local junkyard, and get a pair of wheel chocks from any Nissan of the '80s, and early '90. The ones from a S13 is even better - they are foldable, and very compact, and lightweight.
While you are jacking up the rear, place the chocks to the front end of the tires (assume you are on a level surface, but who will jack up half a car on a slope anyway) to prevent the car from rolling to the front.
I don't understand why the new cars don't come with those anymore. I have 4 pairs of those sitting in the garage. I don't jackup any cars without placing them properly first.
Thanks,
Nelson
Old Jun 23, 2006 | 02:28 AM
MixturePinoy's Avatar
The easiest way is to go to your friends shop and place it on a lift
Old Jun 23, 2006 | 01:42 PM
RebelinRI's Avatar
Front first then rear like someone said. Lift from the lifting points and you'll be fine. It cant roll away because when you lift the wheels on the jack will roll to keep it centered. Don't be scared as long as the jacks are seated correctly, it's not a problem. If you're too low drive up onto some 2x4's or 4x4's and then jack from there. You can make a wedge so driving up will be easier. Now I hope that helps. When you go swimming to you think of "Jaws"
Old Aug 9, 2006 | 12:29 AM
OH6 G35's Avatar
https://g35driver.com/forums/picture-share/110070-jack-stands-g.html
Old Aug 9, 2006 | 10:55 AM
avs007's Avatar
Originally Posted by trey.hutcheson
Jack won't fit under the front of the car even if the front wheels are on wood. And I've just got a mild(.5") drop.
My car is on stock suspension, and my jack barely fits under the front. What kind of jack you using? I noticed floor jacks come in all sorts of sizes.I've seen jacks with low lift capabilities, but the jack housing is still tall towards the back.That's the part on mine that touches the lower-engine cover. (Tallest part of my el-cheapo jack is 6"... I've seen low-profile aluminum jacks, that have the back portion of the jack being close to 7")
Pain in the butt, because it fits, but then you only have like 1" to move the bar up and down. Using a screwdriver gets tiring to jack the jar up
That's why I bought an air-assisted floor jack to hopefully remedy that. I'll let you know how that works, as it arrives next week.
chinee
Jun 10, 2024 07:48 PM
rezendvous420
May 31, 2020 01:26 PM
Frostbite91
Jul 27, 2015 05:25 AM
vstypicals
Jul 20, 2015 10:55 PM
Jadenkid22
Jul 14, 2015 12:33 AM
