G35 & G37, Coupes & Sedans
BESTTT way to launch at the track?
Old Jul 15, 2006 | 01:54 AM
MikeIvoryg35's Avatar
Second time at track (englishtown), this time i used my manual mode ( i have 5at, 2004 coupe) with just an injen intake and greddy sp2 exhaust for mods. I ran a 14.646 at 96.49 mph. Just wondering what is the best way to launch, b/c i tried power braking ?? i think its called when u hold brake down and rev it up a lil...i didnt do it too well and ran a 14.8ish ...Whats the best way to launch the car? just smash down gas? i was hoping low 14s lol help !! thanks
Old Jul 15, 2006 | 02:01 AM
GLuXuRy's Avatar
what i would do is... take out the VDC fuse... power brake... brake with WOT... in MM and shift at rev limiter every time s
Old Jul 15, 2006 | 02:05 AM
godmans's Avatar
I guess you dun want to brake with WOT lol..
torque brake to around 1.5k ~2.5k rpm and then launch
that's what most ppl do.. or simply dun do torque braking
since someone here has reported that the ecu is designed to
pull power when brake and throttle is applied at the same time
Old Jul 15, 2006 | 02:12 AM
Zerk's Avatar
Did you try just smashing the gas on auto? If so, how did that go?
Old Jul 15, 2006 | 02:33 AM
i actually did better just smashing the gas but im not sure if its because i wasnt torque braking correctly lol, is that true the ecu is programmed like that ???? lose power/
Old Jul 15, 2006 | 02:35 AM
GLuXuRy's Avatar
if you brake torque at WOT... your RPMs will not go higher than 2500
Old Jul 15, 2006 | 02:49 AM
so basically hold the brake down, and rev it as much as u can, then just release the brake and floor it when ur ready to go
Old Jul 15, 2006 | 02:51 AM
GLuXuRy's Avatar
fo sho
Old Jul 15, 2006 | 08:41 PM
clindst's Avatar
isnt that really hard on ur tranny?
Old Jul 15, 2006 | 09:15 PM
DaveB's Avatar
You do not want to hold the gas down while on the brake for an extended period because it will build a ton of heat in the torque converter. Nissan recommends no more than 5 seconds. When I race at the strip, I stage, hold my foot on the brake, and once the first set of ambers comes on, I go WOT, and release the brake right after the 2nd set of ambers goes out. That means I'm holding the gas and brake for about 1 second or so. This technique usually results in .5-.6 second reaction times and 2.1 60 foots. I usually see about 2200rpms. Launching without any torque braking results in 2.3 60 foots and a very boggy launch. This car NEEDS a little torque braking to launch. The engine just doesn't have the low rpm torque to push a 3,400lb car off the line hard.
Old Jul 15, 2006 | 11:44 PM
w0ady's Avatar
fgc moderator
dont forget to turn your vdc off. did you see better times in auto or manual mode? the computer can shift the fastest but maybe redlining helped more?
Old Jul 16, 2006 | 02:16 PM
techi13's Avatar
you should just practice peeling out first...
and then practice launching
Old Jul 16, 2006 | 09:37 PM
DaveB's Avatar
I always turn off the VDC, but my car hardly chirps a tire on a track surface. I let the car shift itself on the 1-2 shift, but manually shift the 2-3 and hold 3rd through the finish.
Old Jul 16, 2006 | 09:38 PM
GLuXuRy's Avatar
forgot to mention that lol... ya dont hold it for a long time
KruZZe
Feb 27, 2023 05:04 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
suby01
Not G35 Related
May 25, 2016 03:07 PM
AJC128
Nov 1, 2015 11:55 AM
joel extreme
SOCAL Meetings & Events
Sep 29, 2015 04:44 AM
