G35 & G37, Coupes & Sedans
View Poll Results: What kind of gas do you use?
Super
202
90.58%
Mid
3.59%
Reg
13
5.83%
Voters: 223. You may not vote on this poll
Old Aug 24, 2006 | 03:58 PM
  #46
mephistomyhero's Avatar
Originally Posted by 350Zed
Here in Toronto you'll see this:
Sunoco - 87, 89, 91, 94
Esso - 87, 89, 93
Petrocan - 87, 89, 91
Different distributors carry different grades, but they all market high-octane fuels as "better" for all cars, when this is not in fact true. Most cars will not take advantage of higher-octane fuels than they are tuned for by the factory (i.e., the minimum recommended grade specified in the owner's manual).
Just pick 91 (or the next higher available) and you'll get just what you need for your G.
Ah, I see. OK, thanks and I think I won't be having that problem here. Only 91 available and it's the only grade I use.
Old Aug 24, 2006 | 04:07 PM
  #47
2006_G_coupe's Avatar
93 oct all the time.Prevents knocking and pinging.Plus gets better gas mileage because it burns slower.
Old Aug 24, 2006 | 05:18 PM
  #48
Hmm...wouldn't a higher Octane rating mean it would burn faster? Hence the reason for better performance?
Old Aug 29, 2006 | 12:11 PM
  #49
fortified's Avatar
No, burns less 'instantly' than regular, so it will produce more power under higher compression. You want it to burn quickly, but not explode (detonate). This is why it's a waste to use premium on low compression engines (under 10:1 for a ballpark figure).
Older engines normally running regular might need premium if they have a lot of deposits on the pistons. As these may preignite the fuel charge. But modern oils and fuels leave fewer deposits than cars years ago.
Premium is not giving you MORE performance, just the performance your engine is designed and tuned for. But yes, regular would give it LESS, in this case. As timing would be cut back to prevent detonation.
Old Aug 29, 2006 | 07:51 PM
  #50
Thanks. Learn something new today.
Old Aug 29, 2006 | 08:36 PM
  #51
IP G's Avatar
93 shell v-power
Old Aug 29, 2006 | 10:09 PM
  #52
IvoryGT's Avatar
Originally Posted by Nismo G
Shell V-power 93 octane is the only gas that goes in my baby.
+1, they have by far the best pump gas on the market.
You get better gas mileage with better gas, so why would you pay for a lesser grade?
Old Aug 30, 2006 | 04:50 PM
  #53
Clean G 4D's Avatar
OMG!!! 9 people voted that they use Reg and 5 mid!
Old Aug 30, 2006 | 05:34 PM
  #54
jdmeg21's Avatar
I use premium in my 93 hatchback civic, when gas is cheaper. about 3.15 or less a gallon for 91 premium. when it went up crazy I switched to regular 87 octane. ran like crap, didn't get as good mileage. gas is going back down so I'm gonna go back to premium. by my house they have 102 octane but for 4.85 a gallon no thanks. I'll stick to 76's 91 premium gas. in cali almost all stations carry up to 91 octane.
Old Aug 30, 2006 | 05:36 PM
  #55
jdmeg21's Avatar
so is shell better then 76, because the 76 is 3 blocks away and the shell is at the corner of my street. both use 91 octane here in cali and shell usually gets cheaper before 76 does by a day or two
Old Aug 31, 2006 | 11:38 PM
  #56
uther's Avatar
You know, the funny thing is the G manual says 91 or above, but the FX manual (I have an 05 G and an 05 FX), says that you can use regular. Funny, I thought they had the exact same engine, minus a couple of tuning differences. Go figure.
Old Sep 1, 2006 | 11:38 AM
  #57
tomcatm's Avatar
Dont know about the 76, but you cant go wrong with shell. V-power is the best selling premium brand in the country.
Old Sep 1, 2006 | 11:39 AM
  #58
tomcatm's Avatar
Wow, some places have 93 but not 91? That's really odd. Were's the next grade down? 89? Here in Southern Cali, it's 87, 89, and 91 (premium). I've only used the top three Mobile, Chevron, and Shell. I like Mobile and Chevron the best and mostly fill up on Mobile Premium.
Around Houston, and most of texas as far as ive seen, its 87,89,93.
Old Sep 1, 2006 | 04:50 PM
  #59
jdmeg21's Avatar
I guess I'll be going shell v power then. I've been driving down a couple blocks to get 76, haha and shell is at the corner of my street plus the price is cheaper then the 76 I go to
Old Sep 1, 2006 | 04:54 PM
  #60
BlackOutG's Avatar
since i got my car been putting 91
got my car in 6/24/05
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
prinny
Nov 22, 2015 11:07 PM
NyCrAzY
Oct 1, 2015 09:19 AM
Jay123
Sep 28, 2015 08:42 PM
Hogbone
Sep 28, 2015 06:44 PM
