G35 & G37, Coupes & Sedans
How SGP screwed me over (*very long thread*)
Old Sep 29, 2006 | 05:53 PM
Poptarts's Avatar
Swerving and Weaving
Disclaimer: I am posting this only in hopes of deterring anyone else from going to SGP and wasting their money. This is not necessarily a bash on the shop, but I am merely telling everyone my story with SGP and how I was screwed over.
This all started off back in July of 2005 when my engine leaned out from the Greddy twin turbo kit and the passenger side oil return line was pinched thus blowing the seals on the turbo and cracking the manifold. I had my car towed to SGP in good faith that my car would be taken care of, since the shop that did the turbo install went out of business. They informed me that I had detonation across all the cylinders and there was an 80% leak in the 5th cylinder. They recommended that I buy and install forged rods, pistons, and rings. I did this as well as ordered a set of JWT cams for the new motor. The pistons were Wiseco 8.8:1 compression with titanium rings and Pauter forged rods. I received the car back at the end of November of 2005 with a new motor and a tune on the Greddy E-Manage. I took the car back to school in Lubbock after thanksgiving and noticed relatively no problems. When I came home for Christmas, I had SGP install a new fuel pump as well do the Technosquare ECU reflash because I wanted a few extra hp. They did this and re-tuned the car.
It is now January of 2006 and I went back to school. I changed up the exhaust while up in Lubbock, not thinking it would drastically change the tune and affect the car. The car was still drivable but it was misfiring horribly and having definite fuel problems. I tried driving the car around but decided that it had to go back to SGP in Houston and get this taken care of. In February of 06, I drove the car home 550 miles with a random cylinder misfire and relatively no problems other than that. The next day I’m back in Houston and get on the road to take the car to SGP. I get about 3 miles from my house when the engine overheats. I get a tow to the shop and let SGP have the car. I then flew back to Lubbock to go back to school.
They call me saying that the car is blowing coolant out of the radiator under boost, because the pressurized air is getting into the coolant and pressurizing the coolant. They say this is what is causing the car to overheat, so they run a few more tests and find a crack in the radiator. I authorize them to order a PWR radiator as well as the return fuel system, 770cc injectors, and the e-manage ultimate. I come home for spring break at the end of March 06 hoping to have a working car. I call and SGP says the car is tuned and running great with no overheating problems. I go to pick up the car and as soon as I leave the shop the car overheats. They did not do any actual road testing of the car but merely put it on the dyno-pack with a lot of fans while tuning it. As you can imagine I am quite upset at this point. I take the car back to them and tell them to figure out the problem. They said that the radiator was not fully bled and they would need a day to this. I tell to do that and install a Nismo thermostat since I had not done that yet.
Two weeks later the car is still at SGP because every time I went to try and pick up the car it would still overheat. They were stumped as to why the car was still overheating, but I was fed up with them at this point and told them that I had to go back to Lubbock and finish school. I asked them to install the SGP torque converter upgrade as well as the SGP valve body upgrade. I also asked them to look at the car and try to fix the overheating problem without completely tearing into the motor, because I did not have the money to spend for them to take apart the motor and tell me that the heads are warped and the head gaskets are blown. I come back at the beginning of May 2006 and they swear to me that the car is running great and that they have bled the system and driven it around to ensure that the car is not overheating. I take the car and that day I get into an accident on the freeway because of a woman on her cell phone who slammed on her brakes doing 80mph for some reason unknown to me. I have my car taken to the body shop and have it repainted and fixed. After it was finished at the body shop I had it towed to SGP to have them look and see if everything was ok as far as the radiator and turbo piping. It turns out that everything is fine and they re-bled the coolant system just to be on the safe side. I drive the car home from SGP and to the body shop next day only to run into more overheating problems.
It is now August of 2006 and time for me to go back to school. My dad finally picks the car back up from the body shop and limps it home all the while the car is running on the hot side but not quite overheating. He decides to take the car to Engine Logics and pays for them to take the motor apart and figure out once and for all why it is overheating. They tell us that there is a 30% leak across all the cylinders and the pistons were scoring the cylinder sleeves in all cylinders. The transmission is not making any power until 4200rpms because of the torque converter and the slippage of the transmission; as well the head gaskets on both sides of the motor and both sides of the head were blown in multiple locations across the cylinder head. Engine Logics then checked the heads for any warping, which as it turns out because the engine overheated 5 times, the heads did warp. The total cost for the repairs of this is going to be about $8000.
After all the time and money spent at SGP, I was constantly being treated like a little kid just spending money, because I knew about the VQ motor but I relied on SGP’s knowledge and experience to guide my choices of what to buy. I informed SGP of what was wrong with the motor and they told me **** off and never come back again since my car had been touched by another shop. This, in my opinion, goes to show that even after spending almost $25,000 on parts, labor, and the every frequent “re-tune” with them they were still arrogant and did not want to actually help me get a working car.
Once again, I am only telling this story in hopes of deterring other from going to SGP and getting work done. I have been completely truthful in this and have not lied about anything said here.
Wherever you decide to have your car worked on, please take this story into consideration if you decide that you want SGP to do the work.
Old Sep 29, 2006 | 06:07 PM
speedybc86's Avatar
Man...that sucks. Sorry to hear about your experience. I'd say find a good lawyer. Maybe a call to the Better Business Bureau too, Good luck.
Old Sep 29, 2006 | 06:13 PM
glennp_1999's Avatar
Wow! That sucks big time that is one reason why I don't touch the internals of the motor unless I have to. One thing is for sure if ever I do need to open the engine I will make sure that the shop know what they are doing.
Old Sep 29, 2006 | 07:34 PM
Texasscout's Avatar
Who is SGP?
Sorry, I have never heard of them, I don't live in Houston, but not that far away.
Old Sep 29, 2006 | 09:34 PM
Poptarts's Avatar
Originally Posted by Texasscout
Who is SGP?
they were at one time considered one of the best shops in texas to build and tune nissans and supposedly the best in houston.
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
dcsbh1
Oct 1, 2015 03:15 PM
