G35 & G37, Coupes & Sedans
Just got Pop CHarger/Z Tube IN
Old Nov 3, 2006 | 11:18 PM
nalinc23's Avatar
Just got Pop CHarger/Z Tube IN...small problem
.....and I love it, it's amazing how much more confident and mean the engine sounds at higher rpms now. My only problem/question is when I get on it and it is shifting (5at model) at high rpms, between shifts i hear a quick rattle/shake. Anybody know where I should look to fix this?? Thanks!
Old Nov 4, 2006 | 02:29 PM
ozracer01's Avatar
I just installed the popcharger too..i think the sound you're reffering to is normal...mine does the same thing....
edit: Just doublecheck all the connections...make sure the bracket that came with the kit..is nice and tite.
Old Nov 4, 2006 | 02:49 PM
Callaway's Avatar
Waiting for the same stuff to be shipped to me. You did the install yourself? Should be pretty straightforward?
Old Nov 4, 2006 | 05:09 PM
jdmeg21's Avatar
it's probably rubbing on the a/c tube. put something like a cushion in between the z-tube and the a/c line so that you don't rub a hole into it.
Old Nov 4, 2006 | 05:16 PM
nalinc23's Avatar
It's great man, get a buddy and it will take an hour or so if you do it right. I'd say the most annoying part was actually putting the rubber seals on the heat shield.
Old Nov 5, 2006 | 01:28 PM
V35 Skyline GT's Avatar
6MT Coupe
^^^ +1.
That was the hardest part of the whoe install...lol.
Old Nov 5, 2006 | 01:36 PM
abcquackyxyz's Avatar
Originally Posted by 06CPV35
^^^ +1.
i found the trick to putting on the rubber seal is to work it onto the air scoop, then take it off and put it on the heat shield...makes it softer to work into it. Cover the A/C line with a sliced thick rubber tube and anchor it down with a zip tie.. i also added a rubber washer at the mounting bracket to the car so it can dampen some movement from the intake. just me .02 cents
Old Nov 5, 2006 | 01:47 PM
O HELLA JDM's Avatar
i had the ztube and k&n filter combo before i went injen cai....but it might be that ac thing rubbing on tube...or maybe a loss screw or something that fell into engine bay when u did the install??
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
