G35 & G37, Coupes & Sedans
Should I worry about my transmission or am I paranoid??
Old Nov 19, 2006 | 02:57 PM
nalinc23's Avatar
I have an 04 G35 5AT Sedan with 56k miles and I had a couple questions about some transmission quirks......
1. When it's cold (only for the first acceleration) it seems to slip into gear a little bit if you give it some gas, not a horrible slip but doesn't feel as solid as when it's warm.
2. When the car is in park or drive and you go to put it into reverse at a stop (obviously) once it engages into reverse you can hear a loud "click" sometimes 2 "clicks" from the tranny. Also when you first start moving if you're on a hill in Drive it will make that click once or twice when you first start accelerating.
Am I paranoid or are these signs of a tiring transmission?? My car will be under warranty (extended) until 90k miles, so should I pay the $100 deductible and hope they find something and replace it or just ignore it until it gets worse if it does??? THanks guys
-nate
Old Nov 19, 2006 | 05:12 PM
Msedanman's Avatar
O.F. Administrator
-nate
A good indication of transmission health is the colour of the fluid. If you can't check it, take it in for an evaluation. If there's a problem, the warranty will fix it.
The shop can also scan the Tranny computer (TCU) for any possible issues.
With that mileage, a tranny flush and refill is worth the investment.
G/L
C.
Old Nov 19, 2006 | 07:21 PM
GreenGoblin's Avatar
The goblin resurrection
^ agreed
Old Nov 19, 2006 | 10:19 PM
nalinc23's Avatar
When you say the color is a good indication, what color should it be?? Also do you think any of these symptoms sound bad?
Old Nov 20, 2006 | 03:03 PM
nalinc23's Avatar
Anyone??
Old Nov 20, 2006 | 04:10 PM
Potty_Pants's Avatar
opinion = slipping isnt good, but slipping mis interpreted as a car warming up may be the culprit. imo my autos seemed to rev the engine higher when the car is cold... after it warms up it will tach down.
answer = bolts on drive shaft need to be replaced lubed & washers need to be installed... this is a factory recall. clicking isnt anything to be worried about just annoying.
opinion= drive it till it breaks... or 89k miles ... then have them check it out.
gl
ppp
Old Nov 20, 2006 | 06:46 PM
Msedanman's Avatar
O.F. Administrator
When the tranny goes bad, it burns the fluid which then goes from a bright red to dark brown and also smells burnt too.
Have the dealer check the fluid, and the engagement issue you talked about.
To keep your warranty it's your responsibilty to bring any issue to the attention of the dealer so that he can fix it.
I personally wouldn't like any kind of slippage any time and would have it checked out immediatley.
C.
Old Nov 21, 2006 | 01:15 PM
sfinaki2000's Avatar
Definitely a quick fix at the dealership under warranty. I had the same issue. Technician replicated the noise by pressing the gas while the brakes are presses.
jeffbdye
Jun 1, 2018 03:51 PM
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
f22raptor
Mar 18, 2016 08:50 AM
DRG35R
Jan 31, 2016 07:14 AM
Learned Hand
Oct 1, 2015 09:02 AM
