G35 & G37, Coupes & Sedans
Anyone try the Z32 JWT Popcharger?
Old Dec 11, 2006 | 04:12 PM
jdm rice's Avatar
I've got a Z tube from my bro's 350Z-he's upgraded to an Injen CAI.
Anyways, I've got a brand new Z32 JWT popcharger laying around and looks to have the same MAF pattern as the VQ.
The only difference I see in the filter is that it doesn't have the hole or ram air stack on the top of the filter like the ones i've seen on other G35s. Its just flat and has a bolt on top for support.
Just seeing what you guys thought, can't beat FREE
Old Dec 11, 2006 | 07:20 PM
V35 Skyline GT's Avatar
6MT Coupe
Hey, what the heck. If it has the same MAF bolt pattern, wht not.
Can't beat the price
I'd try it.
Old Dec 11, 2006 | 08:50 PM
sloppymax's Avatar
I used the maf adapter from my old AE maxima (3.0 VQ) and it worked just fine. I am bit confused when you mention a bolt support on the filter though. Do not be concerned if its not an open ended filter with filter element on the top. That will make no difference. As long as it physically fits then you should be fine.
Old Dec 11, 2006 | 11:33 PM
jdm rice's Avatar
here's the one that most of you guys use, with the hole in the top of the filter
here's the Z32 JWT popcharger for comparison, u see that bolt piece now? its there for a support bracket
my only concern is that it won't have the "ram air" effect without the air chamber box, nor do i have a heat shield like this
Old Dec 12, 2006 | 11:04 AM
EverythingG35's Avatar
It'll work and help a little bit, but without the heatshield you may lose a little response in day to day traffic because it'll pull more hot air in at lower speeds. Once you're up to speed the engine bay should get enough airflow, but at low speeds, like sitting in traffic you may notice a difference without the heatshield in place.
The other issue would be with the filter bracket. You'll want to fabricate something to hold the filter and everything in place so it doesn't rub against the A/C line or anything else in the area.
______________
Justin
Old Dec 12, 2006 | 07:38 PM
jdm rice's Avatar
thats what I was thinking, I'm gonna have to hunt a heatshield down
The bracket will be easy to fab up, I'm not too worried about that
Old Dec 12, 2006 | 08:38 PM
Greatwars's Avatar
JWT heatshield is not really helpful anyway, so I don't think you should be too worry about it ... I mean the effect wouldn't be that difference.
11bEMT
May 27, 2022 03:13 PM
Video Share
Jan 31, 2017 04:00 PM
bigmike
Sep 17, 2015 01:58 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
CrazyLogic219
Aug 13, 2015 06:40 PM
