G35 & G37, Coupes & Sedans
programming garage door
Old Jan 18, 2007 | 03:09 PM
SFG356MT's Avatar
for those having issues try this link
http://www.homelink.com/training/video.tml
It's not rocket science but sometimes a video helps.
Old Apr 1, 2007 | 07:04 PM
Q451990's Avatar
I finally got mine programmed. For anyone reading this in the future, this may help out.
My Genie opener came with two full-sized remotes, and one keychain remote. In my experience, you can't set up the homelink system with the keychain remote. I tried that about 15 times. Then I changed over to the full sized remote, an it worked the first time. It appears that the keychain remote works fine with the opener, but not as a source for the signal when programming the homelink mirror.
Heath
Old Apr 1, 2007 | 08:35 PM
JJKK's Avatar
Originally Posted by r15k
i THINK YOU HAVE TO HOLD THE OUTER BUTTONS FOR 90 SEC TILL THE INDICATOR LIGHT ON YOUR REAR VIEW MIRROR FLASHES RAPIDLY, WHEN IT FLASHES RAPIDLY IT MEANS ITS RESET.
THEN GET THE GARAGE REMOTE, HOLD IT CLOSE TO THE REAR VIEW MIRROR. PRESS THE GARAGE REMOTE AND THE HOMELINK BUTTON YOU CHOSE TO USE ON YOUR REARVIEW MIRROR SAY THE FIRST BUTTON. PUSH THE GARAGE REMOTE AND REARVIEW BUTTON TILL IT FLASHES SLOWLY. I BELIEVE THE INDICATOR LIGHT WILL BE SOLID, BUT CONTINUE HOLDING THE GARAGE BUTTON AND THE HOMELINK BUTTON (SAY FIRST BUTTON) UNTIL IT BLINKS SLOWLY.
^ that is all i did, and it works.
and u don't even need to be close to the garage, all u need is the remote.
Old Apr 1, 2007 | 09:19 PM
trey's wife's Avatar
My horns hold up my halo
I didn't read through the thread (yeah, I'm lazy) but on our garage door opener we had to use the "clear" procedure in the owner's manual and then use the programming procedure on the garage door opener itself. The procedure outlined in the manual WOULD NOT work for our opener.
TNRocker
Sep 21, 2015 08:36 AM
Detailed Image
Sep 18, 2015 03:43 PM
Detailed Image
Sep 17, 2015 07:38 AM
