G35 & G37, Coupes & Sedans
Two clicks when I cut the wheel either way
Old Apr 16, 2007 | 04:06 PM
shocktech's Avatar
Hey,
I have a 2004 5AT Coupe, and when I cut the wheel either way 100%, I hear two clicks. Any idea what that could be?
Thanks
Old Apr 16, 2007 | 04:52 PM
Mr.GEE's Avatar
20 Year Member
Do you hear the clicks while turning the wheel, when the wheel is in the same position each time, or only just before you hit the turn limiting stop. My wife's old '95 Maxima did that while turning. Turned out to be the thrust bearings on top of the front struts where they bolt to the strut tower. If you hear the clicks just before you reach the turn limit stop, it could be just need of lubrication on the limit stops.
Old Apr 16, 2007 | 04:59 PM
shocktech's Avatar
Yeah it seems like its JUST before the turn limit...should I just take it to Infiniti and see what they say or is this something that I should be maintaining on my own?
Old Apr 16, 2007 | 05:16 PM
Mr.GEE's Avatar
20 Year Member
If it's under warranty, take it in and let them tell you what's wrong and get them to fix it.
Old Apr 17, 2007 | 08:55 AM
macr6's Avatar
does it continue to click while driving in a circle? could be cv joint and boot maybe.
Old Apr 17, 2007 | 11:03 AM
GT-Ron's Avatar
Most steering racks will click when you bottom them out on either side.
I've always heard it wasn't good to do so, as you're working the rack at it's most extreme angles of operation.
Old Apr 17, 2007 | 12:25 PM
Rphillips6487's Avatar
^^ When i recently lowered my car 2" the alignment guy test drove my car and said he heard some clicking.
could this be the steering rack?
I thought i heard it while turning once but im not completely sure, havent heard any clicking since.. ?:O
Old Apr 17, 2007 | 12:27 PM
xXHotelCrazyXx's Avatar
Never heard of this problem, only the rear axel click which there is a service bulletin out for to get the rear axel bolts either replaced or re-torqued
Old Apr 17, 2007 | 12:32 PM
richboy's Avatar
MORE POWER PLZ!!!
I had this sme problem when i lowered my ride....I found out that it was the front camber kit rubbing on some bolts but it cleared it self after a while.
Old Apr 17, 2007 | 01:32 PM
JJKK's Avatar
the 05 Quest we have
it clicks even during driving, i brought it in to nissan, but they said they heard nothing..
Old Apr 17, 2007 | 04:03 PM
Max4Speed's Avatar
Sounds like your Clockspring. That's normal from what I have seen.
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
