G35 & G37, Coupes & Sedans
removing MAF
Old Aug 14, 2007 | 01:26 AM
Mr.Igor's Avatar
removing MAF
how can i bypass the maf sensor? if i install aftermarket cold air intake... can i bypass it? my sensor is dead!!
Old Aug 14, 2007 | 11:52 AM
Mr.Igor's Avatar
anyone?
Old Aug 14, 2007 | 12:00 PM
Jeff92se's Avatar
Red Card Crew
What? On what basis do you think this is a good thing to do? Do you even understand what function the MAF serves?
Old Aug 14, 2007 | 01:06 PM
keen1801's Avatar
You can always go with a speed density tune, it'll tune out the MAF. If you are looking to do this just to fix the problem, I wouldn't. Save some money and pick up a used or new MAF.
Old Aug 14, 2007 | 01:19 PM
GreenGoblin's Avatar
The goblin resurrection
ya best to get a new one
Old Aug 14, 2007 | 02:09 PM
Mr.Igor's Avatar
but when you put aftermarket intake? it doesnt have the spot for the sensor? or does it? what will happen if i wont have a the maf sensor?
Old Aug 14, 2007 | 02:21 PM
fecurtis's Avatar
I'm not sure how the MAF sensor is designed in the 3.5 L since I do not own one yet (I currently drive a 1999 pontiac grand prix), but not having a MAF will result in decreased gas mileage and performance, for the computer will not know the optimal air/fuel ratio to use. Also, if you take it out, you'll most likely get the service engine light to turn on.
If an aftermarket intake system does not have anywhere to put a MAF in it, heres a simple solution, drill a hole in it, put the MAF sensor in there. I'm not sure how they look like in G's but that should do the trick.
Old Aug 14, 2007 | 02:27 PM
richie's Avatar
uhhh, i dont think your car will start without the MAF
Old Aug 14, 2007 | 02:38 PM
Alan's Avatar
i find it amusing that you think the maf is just an optional piece.
Old Aug 14, 2007 | 03:35 PM
yes there is a spot for the senor on aftermarket intakes
Old Aug 14, 2007 | 04:15 PM
Mr.Igor's Avatar
expensive!
Old Aug 14, 2007 | 04:23 PM
logik05se's Avatar
sure it will....started my 05 maxima when i installed the intake without connecting the maf cable, just gave a CEL light ( shut it rite back off) Took off the battery again and it was gone -=]
Old Aug 14, 2007 | 04:29 PM
Mr.Igor's Avatar
what would happen if i put a g35 maf sensor on qx4?
same HP... both engines are 3.5L.
Old Aug 14, 2007 | 04:31 PM
Jeff92se's Avatar
Red Card Crew
How much could a wood chuck chuck if a wood chuck could chuck wood?
Old Aug 14, 2007 | 04:39 PM
Mr.Igor's Avatar
the resone i am saying that is : http://www.nissanforums.com/pathfind...ternative.html
