G35 & G37, Coupes & Sedans
Water inside passenger side.
Old Sep 10, 2007 | 01:51 PM
brybry2's Avatar
Sorry if this is in the wrong place but in dire need of help.This morning I went to get into the car and the passenger floor mat was full of water from the rain overnight. Last month I installed the groundinggear wires. My question is is there a rubber seal on the inside of the firewall that could have been pushed loose when I ran the wire into the cabin of the car? I need to know this before I go to Infiniti and they tell me it is my fault. I dont see how the water could be coming in from the wire itself since this happened with the car parked when this happened. It has to be from the vent under the outside of the windsheild. Any help PLEASE.........
Old Sep 10, 2007 | 01:53 PM
Hi-TechG35's Avatar
The rubber seal is probally what cause the water to get inside the car. Get some silicone and fill the hole where you ran the wires and you should be all set.
Old Sep 10, 2007 | 01:54 PM
Hi-TechG35's Avatar
Also you can perform a check yourself by just puring some water on the windshield and looking for the leak yourself. Whatever you do I would not go to the stealership until you are 100% sure that the leak is not comming from the rubber seal on the fire wall.
Old Sep 10, 2007 | 01:57 PM
brybry2's Avatar
Thanks guys, I will tear into the under compartment and see if I can see anything. I dont have to poor water as nature is still doing that for me.
Again thanks for the quick reply.
Old Sep 10, 2007 | 01:58 PM
Hi-TechG35's Avatar
Keep us posted.
Old Sep 10, 2007 | 02:05 PM
rookie's Avatar
Permetex black silicone has worked great for me.
If the 07 is like all the others I've see the grommet leads to a pipe that goes straight down into the passenger side and would puddle just like you said during rain or a carwash.
Old Sep 10, 2007 | 08:37 PM
brybry2's Avatar
As suggested I put silicone around the hole created for the wire to pass through. I will try the water test tomorrow and followup.
Again, thanks for the suggestion.
Old Sep 10, 2007 | 09:15 PM
SVLRx's Avatar
undo the grounding gear, go to infiniti and say you got water leaking in your car, everything effected should be replaced underwarranty...
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
G35-R
Nov 7, 2015 01:21 PM
junon
Sep 5, 2015 10:40 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
G35CO
Sep 4, 2015 09:27 AM
