G35 & G37, Coupes & Sedans
E-85... will it run in our cars?
Old Sep 13, 2007 | 03:04 PM
  #31
Dan in St Louis's Avatar
Originally Posted by Jeff92se
it's semantics
Jeff, go Google "Volumetric Efficiency."
Old Sep 13, 2007 | 03:31 PM
  #32
Jeff92se's Avatar
Red Card Crew
Dan, just explain you point
Old Sep 13, 2007 | 04:25 PM
  #33
nr2134's Avatar
Timing will help a bit. But you will need a piggy back to advance it any meaningful amount. So you DO need to run higher compression to take advantage of E85 in any meaningful amount. You can take your miniscule amount and pat yourself on the back if you wish.
If you are referring to timing as it's mentioned in the articles. I'll assume the car is timed to run E85 and has the higher compression already built in. hen the maps are scaled BACK to run normal gas to avoid ping.
And C16 isn't the same as E85. But you knew that right numnutz?
But wait! I just found some information on C16 race fuels! How about dem apples bro! yes, at this point I am poking the stick at ya. Don't take it personal
The OP was asking if we can run E85 in our cars and your simple answer was NO. When in actuality you can and it could be advantageous, but not worth the $$$ IMO.
Then you blurred out that in order to accommodate higher octane fuel in a car you need to build the motor which is wrong. The only fuel that you would have to change things for is E85 which I did point out. He would need a tune which consists of fuel and timing maps and thats because of lower energy content associated with E85.
I also said I can run C16 in my car without problems ........ I didnt say it would be advantageous without FI or higher compression....did I??
I think your definition for accommodate differs from mine and thats why you got your panties in a bunch.
Also in the engineering world compression ratio is not the same as compression pressure, but Ill save you the embarrassment.
And please save me the explanation of what C16 is since I have a drum in my garage for my other car.
Old Sep 13, 2007 | 04:29 PM
  #34
Jeff92se's Avatar
Red Card Crew
You can't run E85 w/o extensively modifing you fuel system. Not that facts are really important here anymore.
Again wtf does C16 have to do with E85? I could say I could run ape **** in my car but that has nothing to do with convesation now does it?
At anytime you want to start making sense, let me know.
Old Sep 13, 2007 | 04:35 PM
  #35
nr2134's Avatar
Me making sense. LOL!!!!!!!!!
I didnt say that in order to accommodate higher octane you need to build the motor. YOU DID!!! Thats why I said I can run C16 in a car without problems.
Old Sep 13, 2007 | 04:41 PM
  #36
Jeff92se's Avatar
Red Card Crew
To take ADVANTAGE of the E85. Which includes what? Altering the fuel system.
Now listen closely. E85 and C16 are NOT the same things. What part of that statement is NOT clear to you?
Old Sep 13, 2007 | 04:42 PM
  #37
nr2134's Avatar
Where did I say that E85 and C16 is the same thing.
Old Sep 13, 2007 | 04:48 PM
  #38
Jeff92se's Avatar
Red Card Crew
When you said you run C16 w/o problems. I never said you wouldn't have problems running C16 now did I?
Look I can run whatever octane also "without" problems. The problem is you are wasting your effort WITHOUT building the engine with that octane in mind. Turbo cars can up the boost. NA cars need to up compression. Running advanced timing won't do much.
Lastly, you cannot overcome the lower energy content of E85 w/ timing mods.
Old Sep 13, 2007 | 07:47 PM
  #39
Still2Slow's Avatar
too corrosive for our engines.... would **** them up.
Old Sep 14, 2007 | 11:50 AM
  #40
Jeff92se's Avatar
Red Card Crew
Actually I think it's just the fuel lines that need to be taken care of.
Old Sep 17, 2007 | 09:36 AM
  #41
manalishi's Avatar
etOH
Ethanol in E85 will oxidize and ruin your injectors.
I don't even know why they market these fuels that are supposed to be cheaper and environ mentally friendly when they take unsustainable amounts of corn to produce the alcohol and it ruins engine parts prematurely. It isn't even that much cheaper IMO.
Kind of a half ***** band aid for a huge problem.
Old Sep 17, 2007 | 02:29 PM
  #42
redlude97's Avatar
There is a section in the owner's manual that specifically addresses E85 and states not to use, good enough of a reason for me
Old May 22, 2009 | 01:54 AM
  #43
Ball.Saxbury's Avatar
I know this is an old thread, but I thought I'd post my results here and bump in case anybody's interested.
I've been putting pure E-85 into my 2008 G35x without any problems yet. I'm in five tankfuls, so I can't speak for longevity.
As for power, and the car is bone-stock, I made some 1/4 mile runs today with an accelerometer, and was running a high 14 (we're in Denver, so remember altitude power losses for being at 5,200 feet). Based on car weight and this 1/4 mile time, I calculated roughly 260 WHP, definitely not "significantly decreased performance" like people seem to think.
I used pure E-85 in my old '96 Mercedes E320 for almost two years, and never had a damaged fuel line, injector, or anything.
Old May 22, 2009 | 09:49 AM
  #44
kvangil's Avatar
I don't know if I'd take that chance. Especially since you're still under warranty, if a fuel-related component should fail down the line, I doubt they'd cover it since you used unapproved fuel. Have you checked your fuel economy to see if it's better or worse? Most MPG with E85 is worse than with regular fuel, so economically it really doesn't make sense to use E85. E85 is really to satisfy environmental peeps and those who want to take away a little from Big Oil's profits.
Old May 22, 2009 | 01:53 PM
  #45
jibberjabbers's Avatar
Read the caution
Hasanbaloch
Feb 29, 2024 08:45 PM
mike730
Jan 12, 2018 04:25 PM
newg37
Jul 26, 2015 09:32 AM
ClwMike
Jul 23, 2015 12:55 PM
vstypicals
Jul 20, 2015 10:55 PM
