G35 & G37, Coupes & Sedans
TPMS issue
Old Nov 27, 2007 | 10:53 AM
scozec's Avatar
TPMS issue
06 G35 5AT
Weather has dipped below -15C here in Calgary, Alberta, Canada.
TPMS has turned on. Seems like the light turns on when it dips below freezing.
Anyone experience this as well?
Old Nov 27, 2007 | 10:55 AM
giddyup69's Avatar
check your tire pressure. with colder weather.. u'll find the psi drop in your wheels. just pump some more air into them.
Old Nov 27, 2007 | 11:21 AM
Coach's Avatar
Your tires will drop (or rise) roughly 1 psi for each 10 degrees F (~5.5C) change in ambient temperature.
You need to readjust your cold pressures for the lower winter temps.
Obviously that's more difficult where ambient temps can vary greatly from day to day, so you might have to shoot for the middle of the range and watch them closely (like weekly).
If you reset your pressures when it's -15C, you could gain easily 5 or 6 psi during your next chinook.
Old Nov 27, 2007 | 11:36 AM
scozec's Avatar
Go Riders Go!
thanks for the info. I will have to readjust my psi on my tires. Usually when i do that, the TPMS light turns off.
Depravity
19 Inch
55
Oct 16, 2015 01:36 PM
cmesidewayz
Sep 29, 2015 09:28 PM
Frankieg35
Sep 9, 2015 12:17 AM
PZ06G
Aug 27, 2015 06:11 PM
TheKnite
Aug 14, 2015 07:59 PM
