G35 & G37, Coupes & Sedans
Rust WTF!
Old Apr 16, 2008 | 07:07 PM
Blackggg35's Avatar
Rust WTF!
i have a couple dings on my car like on the edge of my gas cover and edge of the door and they are rusted i still have warranty is it covered or will the dealer blow it off cause its so small?
Old Apr 16, 2008 | 07:34 PM
Grav's Avatar
Usually the warranty only covers rust that goes through the body, not surface rust.
Old Apr 16, 2008 | 07:56 PM
Blackggg35's Avatar
how do i fix it then? do i have to take it to a bodyshop?
Old Apr 16, 2008 | 08:06 PM
Idyfohu's Avatar
Ouch, I looked at a G35 to buy that actually had rust in the same spot, which tells me obviously that the previous owner was a little careless once while they were putting gas in...sucks.
Infiniti will not cover it, it has to be a defect (I called awhile back), which clearly the above isn't.
You'll have to take it to a body shop, they have to sand/treat/do their thing on the entire panel, to avoid letting the rust spread (this is what Infiniti quickly told me).
Old Apr 17, 2008 | 08:21 AM
giddyup69's Avatar
how big is the area with rust?
i also had rust on my car and got rid of it using a rust removing pen (pen with fiberglass strands in it) and then touching it up with primer and paint. my area was very small. basically a little larger than a rock chip. i had 2 areas that i had to repair. it was a lot easier than i thought. the surface rust was very easy to remove with the pen.
i also bought some rust converter at the time but found i didn't need it because the pen completed the job all by itself.
Old Apr 17, 2008 | 08:39 PM
Curt G's Avatar
Originally Posted by Blackggg35
Rust WTF!
That's what happens when exposed metal, and moisture meet. No need to be surprised.
Sorry, not a warranty issue. Hopefully it's inexpensive to fix.
Old Apr 17, 2008 | 11:33 PM
Blackggg35's Avatar
It's really small size i jsut wish i noticed it before i bought the thing!!!
Old Apr 17, 2008 | 11:41 PM
Blackggg35's Avatar
can't i call the dealership and be like u sold me rust!!!! ???
Old Apr 18, 2008 | 08:15 AM
giddyup69's Avatar
i would seriously suggest just getting a fiberglass pencil:
http://www.mcmelectronics.com/product/SABU10191
with some touch-up paint and/or primer ... you can fix it easily.
unless it's really bothering you.. then just take it into a body shop.
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Visionnn
Oct 3, 2015 05:16 AM
toadfire
Sep 21, 2015 07:15 AM
Mhacker
Sep 12, 2015 07:35 PM
kevintandmd
Sep 3, 2015 06:41 PM
