G35 & G37, Coupes & Sedans
ECU question.
Old Sep 27, 2008 | 01:25 AM
AZ VQ35's Avatar
ECU question.
I just got done doing an extensive search on this topic, However I still need help. I'v read that Reseting your ECU after installing new mods; Intake, Spacer,Exhaust ECt.... can be helpful... is there a special method on how to RESET the ECU correctly I'v heard that by Unplugging the Negative terminal on the BAT for 12+hrs will RESET it.. Dose that method work?...is it even necessary to do this after getting new mods??
Thanks
Old Sep 27, 2008 | 12:22 PM
trey's wife's Avatar
My horns hold up my halo
First of all it is not NECESSARY to do it after you put new mods on. It is not good to make a judgment about the mods for a week or so unless you do it but it isn't a requirement. Your car's ECU will adjust to them but it takes a few days.
This thread is the first Sticky in the Engine/Drivetrain section of the Tech area. https://g35driver.com/forums/engine-...resetting.html Take a look at it and then you should be happier.
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
AT23
Sep 15, 2015 07:44 PM
Terry_G35
Sep 10, 2015 08:17 PM
