G35 & G37, Coupes & Sedans
225-45-17?
Old Nov 8, 2008 | 01:02 PM
blaccG35's Avatar
225-45-17?
hello everybody i just wanted to confirm i can run these winter tires size???
Old Nov 8, 2008 | 01:28 PM
04NismoV35's Avatar
What year? Seems too small. Stock size on sedans from 03-06 was 215/55/17. I got 235/50/17 as a replacement. Which was the closest match. If these are dedicated snow tires that you are planning to swap on/off I would stick with the narrower stock size. Use this tool: Tire Size Calc
Old Nov 8, 2008 | 01:42 PM
blaccG35's Avatar
i have a 06 G coupe...so im guessing 225/45/17 is a no go huh
Old Nov 8, 2008 | 01:52 PM
04NismoV35's Avatar
NG, too small, go bigger. Sound like a honda size. Our cars have a decent amount of meat around the wheels.
Old Nov 10, 2008 | 11:06 AM
MidnightG35X's Avatar
For winter tires, if you are serious about traction, you want to go narrower and smaller, not wider and larger.
Old Nov 11, 2008 | 01:22 AM
blaccG35's Avatar
but most ppl i see on the forum..they go with 225/50/17
Old Nov 11, 2008 | 08:09 AM
GR8TG35's Avatar
I run 225/55/17 all the way around on my coupe with no problems at all.
They have a pretty tall sidewall, and the diameter size is only a 1% difference on the rear compared to my OEM 18"s
Old Nov 11, 2008 | 08:24 AM
pjames's Avatar
i find (from experience), that the width of the snow tires vs performance depends on the kind of snow you're expecting to see, wider tires will tend to plow in deep snow, where as narrow tires will tend to cut through more easily, though wider tires will tend to act more as paddle wheels and the longer "edge" means more snow gripped, best use: packed snow on ice, where you're counting on the snow not moving to get you moving... i guess it depends on what you think you'll see more of.
Old Nov 11, 2008 | 09:56 AM
04NismoV35's Avatar
OP, where do you live? Are u expecting a lot of snow?
Old Nov 11, 2008 | 11:37 AM
On winter tires or regular tires?
Old Nov 11, 2008 | 11:35 PM
blaccG35's Avatar
04nismoV35 - i live in toronto
midnightg35x - on winters tires sorry for not making it exactly clear
chrisamdi
Nov 14, 2006 08:10 PM
