G35 & G37, Coupes & Sedans
View Poll Results: How long do you think your clutch will last (or did it last)?
Less than 10k
3.45%
10k-25k
5.75%
25k-50k
21.84%
50k-100k
43.68%
100k-150k
18.39%
150k+
6.90%
Voters: 87. You may not vote on this poll
My "trick" for herky jerky city driving (6mt)
Old Jan 19, 2009 | 12:39 AM
marcinr's Avatar
20 Year Member
Originally Posted by jabrother
Hi Everybody,
City driving in my 07 G Coupe can be very rough - I especially noticed the other day with a friend aboard getting jostled around when shifting. So I discovered a new trick that seems to work well for me. I start out in 2nd and shift to 4th around 3000 revs. Makes for very smooth city driving under light/mod accel. Of course if the need arises I can revert to traditional shifting. Yes you have to slip the clutch to start in 2nd but surprisingly doesn't take much to get going and it's very smooth if you do it right... just takes a little practice. Besides, my clutch, at 20k miles, already feels messed up (takes up in different points sometimes and is not progressive) so I don't think it's a big deal since it'll probably fail prematurely anyway. Maybe this will help you if you're having trouble driving smoothly in the city.
Cheers!
James
Oh dude, don't do that, that's a lot harder on your clutch than shifting more often. The 2nd gear start has to do a lot of slippage to not stall the engine, and slippage is what wears clutches. Perfect rev-matched shifts barely wear it at all.
Old Jan 19, 2009 | 05:41 AM
Dranom's Avatar
how about resting your foot on the sidewall? that why theres a rubber protector thingy in there. coz w/o any support you will jerk the car
Old Jan 21, 2009 | 04:00 PM
jfats100's Avatar
Can you communicate this a little better? It just doesn't make sense to me.
Old Jan 22, 2009 | 11:34 AM
amf25's Avatar
don't start in 2nd, 1st is made for a reason... smoothness come with technique, technique comes with time.. keep practicing!
Old Jan 22, 2009 | 11:38 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Hi Everybody,
City driving in my 07 G Coupe can be very rough - I especially noticed the other day with a friend aboard getting jostled around when shifting. ..............
Cheers!
James
Get his done & smoooooooth shifting will ensue
Old Jan 22, 2009 | 11:53 AM
twin001's Avatar
you should really change gears sequentially too, don't skip shift (2nd to 4th w/o going through 3rd).
Old Jan 22, 2009 | 12:19 PM
mishap's Avatar
I think that's for 2nd Gen G's...He has an '07 Coupe meaning its a 1st Gen.
Old Jan 23, 2009 | 12:58 PM
Beebo's Avatar
Whats so hard about starting with first gear?
OP you have to know how to love your clutch
Old Jan 23, 2009 | 02:32 PM
G force's Avatar
I didn't think skipping gears was a problem when I first bought my car until I did some more research. DO NOT SKIP GEARS in the G35's close ratio transmission, it says it in the manual. I still do sometimes, but I pass it through the gear(s) that I am skipping.
I do find myself using 2nd a little more at near stops or split second stops than I should - at the expense of my clutch. I do this because I feel like getting into 1st when coming to a stop works the synchros too hard, maybe its just my car, but it is not smooth unless you are dead stopped.
I agree with the herky jerky nature of the G, and yes, I probably do need more practice. For the most part I can keep it smooth, but every once in a while I get that abrupt jerk. I used to always see passenger heads bobbing on 1-2 shifts. It has gotten smoother but still happens to a degree. I think its just the reality of having a manual with this gearing.
Old Jan 23, 2009 | 02:48 PM
jabrother's Avatar
I'm not sure what is meant by 2nd gen. They changed the clutch with the revup in 2005. So I have that setup. I'm sure they changed it again with the redesign so technically that would be 3rd gen.
Thanks everyone for the input. I can drive the car smooth but it takes waaaay more patience than it should. I have a 96 240sx with 230,000 miles on the original clutch (and everything else for that matter) and it's as smooth as any manual trans car I've ever driven. It really makes a big difference in driving pleasure. So it's not that I don't know how to drive smooth it's just that it takes more effort than it should, in a 35g + sports coupe. It actually feels like my clutch takes up at different points sometimes. Sometimes very jerky lower in the travel, then other times it will slip really bad on a 1-2 shift at a high take up point. It feels inconsistent and not linear at all! Do I have a defective clutch or are they all like this? From the reviews I've read it seems like a common problem that only an aftermarket clutch would fix.
Old Jan 23, 2009 | 02:50 PM
jabrother's Avatar
Wow, thanks for this! Was not aware of it and sounds like a great DIY to improve clutch operation.
James
Old Jan 23, 2009 | 04:20 PM
ItsYaBoi's Avatar
lol at you MT drivers!!!! auto all the way baby
Old Jan 24, 2009 | 05:28 PM
jfats100's Avatar
Can you explain the reason for why it is bad to skip gears (besides the owner manual saying that)? I have heard this before but never got a really good explanation. I have a fairly good understanding of how MT works, it's a purely mechanical system - in which case, skipping gears would not do any damage (as long as you're rev-matching properly). Anyone got the in-depth mechanical answer for this? (Or a good thread to read?) Thanks.
Old Jan 24, 2009 | 11:28 PM
  #30
jabrother's Avatar
I agree, never heard any specific "rule" that you can't do that. As long as you're not overly slipping the clutch or not matching revs very well what's the problem, especially in slow city traffic? In fact if you read a C/D review I remember them saying they were skipping gears in either a Z or G all the time because of the available torque.
