G35 & G37, Coupes & Sedans
Bubbling Water Sound
Old Feb 20, 2009 | 02:16 PM
Villafan's Avatar
I recently wrecked my 2003 Sedan G35, I got the car back two days ago from the shop. It was over heating so i took it to the dealer and they replaced the thermostat. But now when i am driving i hear a sound like water bubbling and boiling behind the glove compartment. I called the dealer and they said that noise is common for this model and is not a problem. Has any one had this issue....
Old Feb 20, 2009 | 02:31 PM
Todd157k's Avatar
The system (any car) has to be purged or "burped". If they didn't do it, there could be air trapped in there. Then the pump cavitates and no flow. Take it back to them and have them check it.
Old Feb 20, 2009 | 03:08 PM
Texasscout's Avatar
There is a bleed valve behind the Plenum that will let the air out.
See page 11: http://www.g35frenzy.com/downloads/2...anual/B/co.pdf
Old Feb 20, 2009 | 04:24 PM
MidnightG35X's Avatar
Sounds like air that is making it to the heater core.
Old Feb 20, 2009 | 05:03 PM
insydiusg35's Avatar
Dealer should know that the system needs to be purged when new fluid is added.
Old Feb 20, 2009 | 10:14 PM
Progress's Avatar
Shouldn't the cooling system automatically bleed?
Alternatively, I think you can remove the radiator cap as the car warms up and air will release.
Old Feb 21, 2009 | 10:02 AM
Texasscout's Avatar
No it won't bleed by itself. The blead valve in back of the plenum is at a higher level than the rad cap.
Old Feb 21, 2009 | 03:11 PM
bflemi3's Avatar
It would if the rad filler neck was the highest point. But it's not. The bleeder cap is higher.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
