G35 & G37, Coupes & Sedans
19's or 20's tire size
Old Mar 25, 2009 | 12:01 AM
lspilot82's Avatar
Hey guys im new to the board and i was wondering what size tire should i go with for 19's? I wanna keep the speedo as accurate as possible. And if i decide to go with 20's what size? Thanks a million.
Old Mar 25, 2009 | 12:04 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
245/35/19F 275/35/19R is standard for 9.5/10.5 setups... if you want more meat on the tires, you can go 255/35F 285/35R
245/30/20F 275/30/20R is standard for 9/10 or 9.5/10.5 setups. once again, if you want a wider setup, go 255/30F 285/30R
-GP-
Old Mar 25, 2009 | 12:07 AM
lspilot82's Avatar
With the 20's and the wider tires is there a clearance problem. And is there a clearance problem at all with the 19's or no? And those tire sizes keep the speedo pretty close?
Old Mar 25, 2009 | 10:55 AM
BostonG6spd's Avatar
actually the ideal size hight (middle number) for 20's is 35 front, and 30 rear. that is as close to factor spec as you can get w/20's, and it wont mess with your speedo.
Old Mar 25, 2009 | 04:21 PM
lspilot82's Avatar
thanks for the info guys
vitamin.v
Nov 7, 2019 06:10 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
mryogi
Aug 14, 2015 07:58 PM
Jnm07
Aug 6, 2015 03:03 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
