G35 & G37, Coupes & Sedans
Manual shifter buzzes and rattles at higher Rpms?
Old Apr 3, 2009 | 04:35 PM
jpnelson1978's Avatar
It's a 05 sport coupe manual. At higher rpms it buzzes. If I hold my hand firm on it I can prevent the buzz. Anybody have this problem or solution
Old Apr 3, 2009 | 05:28 PM
maciejk's Avatar
prolly normal i get a loud rattle above 6000rpm
Old Apr 3, 2009 | 08:43 PM
Curt G's Avatar
Stock **** or aftermarket? If stock, has it ever been removed?
Old Apr 3, 2009 | 09:02 PM
dofu's Avatar
20 Year Member
Take the shift **** off and you will see a little metal ring on the shifter. I have no idea what it is, but thought it'd be a good idea to keep it there, so I just took the ring off and tightly wrapped the shifter (everywhere it'll make contact with the ring) with enough electric tape so it'll be a snug fit when you put the ring back on. Put the ring on and tightly wrap it with a little more electric tape so it doesn't move around at all. Put your shift **** back on and see if it still makes a buzzing sound. If the sound is only dampened, do this over again.
Old Apr 6, 2009 | 09:42 PM
bp240's Avatar
damn mine doesnt buzz but you can definitely feel it rattle, my clutch is worse, when depressing it with medium or high revs, you feel a lot of vibration
alessandro
Oct 8, 2015 09:29 AM
sullivan72
Sep 22, 2015 11:39 PM
TNRocker
Sep 21, 2015 08:36 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
