G35 & G37, Coupes & Sedans
Too late to debadge??
Old Apr 21, 2009 | 10:24 PM
4DGS's Avatar
Originally Posted by mysterymann
I removed the G35 but it shows up lighter than the paint what should I do??
It is a Laser Red Coupe
Polish it up and give it a few days/ few washes. It'll even out.
Old Apr 22, 2009 | 07:48 AM
Mustang5L5's Avatar
And if it doesn.....put the G35 emblem back on
Old May 5, 2009 | 09:10 PM
SrALezza's Avatar
I hate to be negative but I took mine off 2 months ago on a 2005 lake shore slate in Florida and you can still see the difference. I did it right and there is no residue but you can see the old paint darker.
Old May 5, 2009 | 09:25 PM
Vrod-Mike's Avatar
I just took mine off and there is a very slight color difference. On my car though the paint under the letters was lighter then the rest. You really can't see it unless you get right up on top of the car so it's not real bad. I'm hoping it will blend in with some exposure to the sun.
Old May 5, 2009 | 10:39 PM
BigGrz's Avatar
I had my car detailed immediately after, and they did a lot of polishing to get the swirls out so that probably helped.
Old May 6, 2009 | 12:10 AM
Vrod-Mike's Avatar
I detailed my trunk as soon as I finished using the two step Menzerna polish and then a sealer. It looks great, but there is definitely a difference. My car is also 4 years ols so that certainly has a lot to do with it.
Old May 9, 2009 | 12:06 AM
NumbersMan's Avatar
I just took the INFINITI off the the back of my '05 G35, it took less than 30 minutes and there is no noticeable difference in color. Here was my method:
Use dental floss to take of the letters (didn't even need to use hair dryer, maybe because it's an '05 and the glue has had time to deteriorate???)
Spray some Turtle Wax Bug and Tar Remover on the adhesive left on the car. Let it sit for a minute or two.
Wipe off spray with a towel (this will only take off a little of the adhesive) and then take a hair dryer to the leftover adhesive for about 30 seconds and use your thumb to remove gunk (should just rub off now).
If there is any of the adhesive left after this, spray again with Bug and Tar Remover, let sit for a couple minutes and then wipe off with towel (probably won't need to use hair dryer this time around).
Clean area and it's done.
Old May 9, 2009 | 11:18 AM
AVATAR77's Avatar
What color is your G?
Old May 9, 2009 | 11:58 AM
NumbersMan's Avatar
Lakeshore Slate
Old May 11, 2009 | 12:40 AM
gdjck86's Avatar
youll be fine, i debadged my 04 LR coupe and it matched up after a few weeks in the sun
Old May 11, 2009 | 08:19 AM
pwebb's Avatar
I recently did this to my Volvo. its a 94. cant even tell it was there
NyCrAzY
Oct 1, 2015 09:19 AM
Benja455
NorthWest
Sep 23, 2015 01:10 PM
