G35 & G37, Coupes & Sedans
Question? 6th wheel stud on Front
Old May 19, 2009 | 02:33 AM
thecos54's Avatar
wheel hub. I was putting on my new rims and tires. I changed the back one with no problem, but when I got to the front I notice a extra stud or peg and cant fit the front tire on. I have read that it is just a stud so that the factory wheels do not get rotated. Can anyone help me with this. I have put a pic so you can see what I am talking about. Thanks
Old May 19, 2009 | 03:16 AM
jdmgee35's Avatar
Someone just asked this recently.. but I know it's probably hard to search for something like this.
yes, it's safe to remove, don't worry about it. It is as u say.
Old May 19, 2009 | 03:21 AM
ShanesG's Avatar
Just take it off, it's just to prevent you from putting the oem wheels on wrong!
Old May 19, 2009 | 10:29 PM
dave's Avatar
^^ What they said.
Old May 20, 2009 | 01:04 AM
thecos54's Avatar
Thanks everyone. I took it off and put my new wheels on. No problems yet other that the TPMS went on. Just need to figure if there is a way to disarm it now.
Old May 20, 2009 | 10:41 AM
brandon402's Avatar
From what I understand, TPS cannot be disabled. However, I have heard of folks putting all their sensors inside their spare, inflating the spare to proper psi, and thus tricking the TPS system. However, Im not sure if the g35 has the ability to determine positioning of the sensors (i.e. whether or not they are located where they should be on each wheel).
Old Jul 6, 2020 | 05:04 PM
Jeff Michel's Avatar
infiniti G35 coupe
Having the same problem
I’m having the same problem where I have an extra stud is it really safe to remove it and won’t affect the performance of the car. If so how do I remove it
Old Jul 6, 2020 | 05:23 PM
Scorpi0's Avatar
Yes. Its a bolt head, just turn it with a wrench.
Old Jul 6, 2020 | 06:07 PM
infiniti G35 coupe
6th wheel stud
sounds easy enough so I won’t encounter any future problems due to me removing this extra piece
Old Jul 6, 2020 | 08:55 PM
Mr.GEE's Avatar
20 Year Member
The 2003-2004 coupes for sure had different size tires in the rear than the front. Two of the stock rims had a relief hole for the extra stud to nest into. This was to prevent mixing the tires from front to back and vice versa. For cars equipped with the 18" wheels the rims were the same size, however the 17" rims had a different offset in the rear than the front. so the extra stud prevented them from being mixed. If you are replacing the rims with aftermarket, you can remove the extra stud, just make sure they don't interfere with the brake calipers.
rezendvous420
May 31, 2020 01:26 PM
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
Soumilg
Jul 18, 2015 12:33 PM
