G35 & G37, Coupes & Sedans
K&N Filters
Old May 31, 2009 | 09:16 PM
nopama's Avatar
K&N Filters
I have had A couple of people tell me not to use K&N airfilters becouse the oil can screw up the O2 sensor any thoughts?
Old May 31, 2009 | 09:23 PM
KAHBOOM's Avatar
I used them on my G35 coupe and now I hav ethem on my G37- no issues at all.
I imagine that if you over oil them after you clean them you might potentially create a problem.
Old May 31, 2009 | 09:57 PM
blazeplacid's Avatar
just make sure you let the oil dry a bit before putting the filter back in
ive never heard of anyone having a problems with any oil based filter
only place where ive heard concenrs is in on the internet.......
Old May 31, 2009 | 09:59 PM
EL-EE-ES's Avatar
only if you oil them too much
Old May 31, 2009 | 10:49 PM
OCG35's Avatar
The O2 sensors are at the exhaust manifold and catalytic converter – filter oil is not going to end up at either of those locations… I think you are referring to MAF (mass air flow) sensor, which is just after the filter… if oiled properly it wont be a problem. Even if oil residue ends up on the MAF sensor, it can be cleaned.
Old May 31, 2009 | 11:38 PM
gary c's Avatar
K&N Intake Filters.
I've been using K&N filter on all my rides for the past 20 years and have never had any issues. I always clean mine every 2 oil changes which is 6K miles. If you'll follow the instructions on the kit making sure the filter is dry when you reinstall it you should be very satisfied with K&N....
Gary
Old Jun 1, 2009 | 01:18 AM
TheTick's Avatar
I've also had K&N's for years and never had probs. I won't use them on my G, but I've had one in my Explorer for over 30k miles and it still doesn't need cleaning.
Old Jun 1, 2009 | 05:49 AM
nopama's Avatar
Thanx for all the input.
Old Jun 1, 2009 | 07:13 AM
pwebb's Avatar
I have heard that Ford wasnt honoring warranty on their turbo trucks if they found out a K&N was used.
apparently they pass so much dirt that the inside of the intercooler pipes were sand blasted to a chrome finish which ate up the turbos...
Old Jun 1, 2009 | 09:19 AM
brandon402's Avatar
Same as everyone else has said, been using K&N for years with zero problems. However, I heard recently that they are offering a new "dry" filter. And that its supposed to flow better than the oiled ones. Anyone hear about these?
Old Jun 1, 2009 | 12:00 PM
TheTick's Avatar
Wow...I know K&N filters let more dirt in, but thats ridiculous.
Old Jun 1, 2009 | 12:42 PM
RADIOGUY21's Avatar
meh, Ive had mine in for a about 20K and have no problems. Out of the box they are fine, but when it comes time to cleaning and re-oiling is when people tend to use too much oil or not allow proper drying time. That can result in oil slinging onto the MAF screen.
Old Jun 1, 2009 | 03:28 PM
Mustang5L5's Avatar
I've run em for years with no probs.
In fact, the G35 is the first car i've owned where i haven't installed a K&N. No clue why not yet
Old Jun 1, 2009 | 05:23 PM
TheTick's Avatar
I like them because you almost never have to change/clean them. Makes life a bit easier for my cars that I don't put alot of miles on.
I drive a ton in my G so I want the superior protection of a paper filter. I also enjoy maintaining my G so it's fun to install a nice clean paper filter.
Old Jun 1, 2009 | 10:19 PM
Blue Lion's Avatar
My 2007 G35c has 1 with no issues.
