G35 & G37, Coupes & Sedans
air conditioner pissing me off !
Old Jun 9, 2009 | 04:01 PM
bukrickay's Avatar
I have this problem for about a year now and im frustrated! just wondering if anyone has this issue or know how to deal with it.
ok when it is like 70 degrees outside the a/c is cold/average.. when its like 85 and up the A/c system is like a fan but at high speeds it's a little cool but not cold at all. Today in Texas its like 95 and I was sweating driving home from work. Could it be the compressor, belt, expansion valve, evap?
Old Jun 9, 2009 | 04:06 PM
marcinr's Avatar
20 Year Member
Sounds like a typical symptom of being low on refrigerant (cheap) or a compressor which is getting weak (expensive). Take it to a mechanic who knows A/C systems.
Old Jun 9, 2009 | 04:12 PM
bukrickay's Avatar
i have try charging the system like 4/5 time this year I vaccum the old freeon out and put artic freeze in and still same ol. i guess it might be the compressor since the a/c still works. so i guess im go look around for one..
Old Jun 9, 2009 | 05:35 PM
pwebb's Avatar
you personally vacuumed out the system? how?
or are you saying you've gone to a shop 4 to 5 times this year ...
Old Jun 9, 2009 | 06:11 PM
Mustang5L5's Avatar
If you are doing it yourself, are you putting r134a in with the correct pressure gauges hooked up to the low and high side....or you just shooting a couple cans in and crossing your fingers?
Old Jun 10, 2009 | 01:13 AM
bukrickay's Avatar
well i put the 134 in the Low side, and im pretty sure you leave the high side alone.
Old Jun 10, 2009 | 01:25 AM
bukrickay's Avatar
i have a vacuum pump it sucks all the freeon out and I put another 2 cans in the system.
Old Jun 10, 2009 | 08:47 AM
Mustang5L5's Avatar
Correct, but if you are just blinding attaching cans and filling it then you have no way to determine if the pressures are correct.
The correct way to fill the a/c system involves hooking up gauges to the high and low side and filling through the low side until specific pressures are obtained on both the high and low side. That pressure drop is what gives you nice cold a/c. If you are just filling blindly, you won't really ever know if it's optimal at all. That could be a reason why your a/c doesn't feel cold.
You really need a setup like this to properly recharge an A/C system. The parts store guys never tell you that.
Old Jun 10, 2009 | 10:20 AM
KSWAY's Avatar
Try letting some out.
Old Jun 10, 2009 | 10:44 AM
pwebb's Avatar
you need to vacuum down the system, and hold that vacuum (28"Hg) for 15 minutes.
this will boil off any moisture in the system. yes, water can boil at room temperature. pretty sweet to see. as well as determine if you have a leak.
Old Jun 10, 2009 | 10:50 AM
Mustang5L5's Avatar
You also need to make sure you add the correct amount of oil as well as 134a when you charge the system. You can't just add freon only.
Old Jun 15, 2009 | 10:26 PM
bukrickay's Avatar
alright thanks guys...
Old Jul 5, 2009 | 08:19 PM
2QU1CK's Avatar
i have a different problem, but simillar....at 60 degrees, its ice cold.....at 61 degrees, its hot like 80 degrees.....any suggestions? sorry, not trying to take over your tread bukrickay
KruZZe
Feb 27, 2023 05:04 PM
KallDay86
Jan 8, 2016 12:42 AM
Learned Hand
Oct 1, 2015 09:02 AM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
