G35 & G37, Coupes & Sedans
Need help after installing back my 18's
Old Jun 14, 2009 | 09:35 PM
Missile558's Avatar
Brakes Need help after installing back my 18's
I installed my 18's back after selling my 20" MMR HR4. here's what happened. If i drive my car w/o turning the VDC off the ABS,SLIP and VDC lights turns on? but the brake is working fine. but if i turn the VDC of, evry time I steped on the brake the ABS is kicking in? and my brakes are weak I tried to reset the ECU using the gas pedal method and even took the battery connection of for 3 hours but nothing happened any body encountered this? need help ASAP! i'M GETTING FRUSTRATED!
Old Jun 14, 2009 | 09:50 PM
Glex25's Avatar
Administrator
1.check your brake fluid
2. check to see if the abs sensor/line was move/cut during the removal of the wheels
3. check your brake pads
Old Jun 14, 2009 | 09:58 PM
Missile558's Avatar
Thanks! I'll check it this weekend.
Old Jun 15, 2009 | 01:16 AM
BuckeyeInMI's Avatar
Next weekend, as in 6/20-6/21? You should check them sooner than that, like Monday 6/15, not next Saturday. If your brakes are "weak", then you're taking a bit of a risk in driving it.
Old Jun 15, 2009 | 11:49 AM
05DGx's Avatar
^+1, The man speaks the truth.
If you are having a potential problem with your brakes, I wouldn't go driving around normally until the weekend. Why risk it?
I would think that you're having an issue with the ABS, #2 on Glex's list, but check all three, as they are the most likely reasons you're having a problem.
If you had low pads or brake fluid, I would have imagined you'd have the problem with the MMR's on too.
Old Jun 15, 2009 | 06:45 PM
Missile558's Avatar
The car is drivable and brakes is ok but ABS.SLIP,VDC light is on, checked all the fluid and everything is ok. Talked to my service3 advisor and he told me that it's a sensor mulfunction. He told me that the car is drivable just need to checked the sensor. brakes are week if i turn the vdc off before moving the car.
Old Jul 12, 2009 | 10:05 PM
Shawn87's Avatar
I have this same problem except i was running 19s... anyone have any other solutions??
Old Jul 13, 2009 | 04:45 AM
Missile558's Avatar
Solved the S***ID problem! after all the things I've been thru! the only problem is my reaer tire! Got a new set of tires cause I forgot I only bought used tires before installing mi 20's. But it didn't stop there. I bought A higher size tire on the rear and that makes my brakes to actuate and having a rattliong sound on the passenger side.
First I got 255/45/18, returned them and got 255/35 and solved the problem. So Shawn, check your rear tires and see if it's time for a new set. let me know.
__________________
2003 G Coupe/ Injen CAI/ 5 1-6 plenum spacer/ 6000k HID bulb/ Megan racing "Y" pipe/Megan Racing Headers/ Nismo GTR seat badge/ Skyline 350GT Badge/ Skyline Grill/Nissan steering wheel emblem/Buddy club grounding kit.
Old Jul 13, 2009 | 11:57 AM
Shawn87's Avatar
__________________
It started sat after I got brand new tires installed all around.. Im trading it in this week hopefully so i guess its their problem now.
Old Jul 13, 2009 | 10:03 PM
Mustang5L5's Avatar
Lol, that's almost a 2" difference in tire size! No wonder the ABS light came on.
Old Jul 13, 2009 | 11:34 PM
And neither size is very close to stock. Stock rear 18's on a Coupe are 245/45-18, or 26.7" in diameter. The 255/45 is over 27" in diameter, and the 255/35 is barely over 25"! I think that's WAY too small. Your speedo is going to be off by over 6%. If you want a 255 width tire, then 255/40 is a much better size than either one you chose. If you still want to maintain roughly the same front/back ratio on tires as stock, you'll need to put something very small up front, like 235/35-18.
Why not stick with 225/45 F and 245/45 R? There's a very good selection of tires in those sizes.
Old Jul 14, 2009 | 07:31 AM
Shawn87's Avatar
I just bought new 225/45 and 245/45 then my problem occured... maybe i need a new sensor
chinee
Jun 10, 2024 07:48 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
EnCr1pt3d
Jul 29, 2015 03:35 AM
apintojr
Jul 23, 2015 10:52 AM
justgotg35
Jul 19, 2015 12:33 PM
