G35 & G37, Coupes & Sedans
Clutch Pedal Sticking
Old Jul 5, 2009 | 08:30 PM
EF21's Avatar
Exclamation Clutch Pedal Sticking
I was driving my G on the mountain pass this afternoon. On the way up it was fine but when i hit the top and turn around to come down my clutch pedal was sticking once I made a gear change. It was when i would release the pedal it would get stuck and few seconds later it would pop out about half inch to the normal position. So i got scared and slowed down. Once i got off the pass i drove normal again and it went away. Has any one had the same issue or should i worry. I do drive spirited once in a while.
Old Jul 5, 2009 | 09:24 PM
sfgr415's Avatar
Myself and Andy2434 have had similar issues with our 2005 6MT Coupes. We both live in San Francisco, and have realized that this only happens on extremely warm days (80+), which are uncommon here. In my experience, this starts to happen after a lot of stop and go traffic. Maybe the car just gets too hot?
We are both now out of warranty and neither of us could replicate the issue at local dealers, although Andy says he may have done so recently.
I did a search a while back on this topic and found some threads in which people were switching out their fluid for higher temperature fluid.
Old Jul 5, 2009 | 10:07 PM
Texasscout's Avatar
Happened to me on my 05' sedan. Dealer flushed the system and all has been well for almost a year now. I think you get air in the system.
Old Jul 5, 2009 | 10:20 PM
EF21's Avatar
Thanks sfgr415. It was hot on the pass like 92 my G has lil over 32K and working on changing fluids out, would altitude change anything due to living around 5600 ft and going up to 9600 ft. Yeah i live on the eastern sierra nevada and it gets real hot in the summer as well as snow in winter
Old Jul 5, 2009 | 10:45 PM
Texasscout's Avatar
going up that high would just increase the size of any air bubbles in the system. So does heat.
Old Jul 5, 2009 | 11:00 PM
sfgr415's Avatar
Andy2434 was telling me that the dealer would probably replace the fluid in his system. Seems consistent with what everyone has mentioned.
In my 2.5 year ownership of the vehicle, I have probably experience this issue about 5-7 times.
Old Jul 6, 2009 | 12:21 AM
izzueeek's Avatar
Yah I have a similiar problem. When there is heavy traffic and when I drive for a long time before turning off the car. Is there a way to fix it? Mines a 2005 6MT.
Oh btw, my clutch is like brand new with like 500kms on it.
Old Jul 6, 2009 | 12:58 AM
gary c's Avatar
You can change the fluids and see if it occurs again, chances are it will because the culprit is the clutch cylinder. Try doing a SEARCH under clutch problems, there's been several threads due to this issue. I replaced the cylinder twice with my Z, changing the fluids is a temp fix....
Gary
Old Jul 6, 2009 | 01:27 AM
oyoquem's Avatar
Gary
Did you change the master or slave?
Old Jul 6, 2009 | 10:45 AM
three.five's Avatar
Had the same problem yesterday as well... it was a hot day, and i was driving a bit enthusiastically. My clutch also makes a funny humming noise when engaged, but not when released. I made an appointment at the dealer for tomorrow... hopefully it is covered under the factory warranty.
Old Jul 6, 2009 | 11:04 PM
fresh_06'G35's Avatar
ive had this problem about 3 times now and it is a bit annoying but since its not common im not to worried. i always thought it would be the throw-out bearing sticking but never had it looked at. glad i saw this thread. three.five it sounds like your throw-out bearing is going out.
Old Jul 7, 2009 | 09:44 AM
pwebb's Avatar
well, I just had a car come into the shop with this issue. the pedal would occasionally stick. hydraulically everything felt fine.
I pulled the tranny down to find clutch material everywhere. the pressure plate and flywheel were quite over heated as they were very blue. this thing was getting HOT.
the clutch material had gotten all over everything, not allowing the grease to properly lubricate. when moving the fork by hand, you could feel it binding up on the input shaft. this was clearly what was being felt in the vehicle. I cleaned everything up, gave it some grease, and everything was good.
Old Jul 7, 2009 | 02:44 PM
three.five's Avatar
It is great to have an online forum. I dropped off the car at the dealer today. They took a look at it and said that the bearing was having a hard time catching the clutch because it was sooo warn. They wanted 1300+ to replace the clutch saying that i caught it in time to not have the flywheel replaced, but if i waited and needed that replaced, it would be an extra grand.
Maybe this weekend I will get a buddy and do what pwebb did, see what happens...
I know I can search (and will), but might as well get as much info as possible... what would you guys do if I infact have to replace the clutch already? do the flywheel while i am in there? My car will never be 450whp, but i will do some light modding along the way...
Old Jul 7, 2009 | 10:41 PM
Texasscout's Avatar
Jim Wolf Technology Clutch pack and flywheel is highly recomended by many member here. I runs about $650-700 last time I looked. Get a good mechanic to put it in for you.
FWIW, I have over 80K on mine and the clutch is fine. Someone here has over 120K with the original clutch.
mbe32
Nov 13, 2015 11:09 PM
AL8782
Oct 3, 2015 10:26 AM
dcsbh1
Oct 1, 2015 03:15 PM
Hogbone
Sep 28, 2015 06:44 PM
jbmw002
Sep 10, 2015 12:54 AM
