I have an '04 G35x that needs a front driveshaft. Dealerships quotes me $800 for the part and $200 labor. Does this sound right?? I did a quick search and found one on eBay for like $125 plus $35 shipping.. If anyone knows a reliable place to buy just the front driveshaft on an 2004 AWD G35 please let me know. Thanks.
gary c
close
- Join DateFeb 2005
- LocationValencia, Ca
iTrader Positive Feedback100
iTrader Feedback Score(10)
Liked:1,133 Times in 1,003 Posts
Gotta ask, "Why do you need a new driveshaft?" Nation wide are shops that specialize in driveshafts and their repair. Rather than taking a chance on one from eBay find a driveshaft repair shop in your area, use your Google!
Gary
Gary
I'd be cautious getting a cheap aftermarket drive shaft. Not that it will break (although it might), but the torque specs on an aftermarket may not be correct. And by torque I mean the rotational forces placed on it by the transmission. It's likely to have more flex than an OEM shaft (shaft flex, ouch!), and that could put unwanted stress on the tranny and pumpkin. Find a used OEM instead.
And shouldn't that be covered under the drivetrain warranty? Or are you over 70K miles?
Quote:
This begs the question what was wrong with it?Originally Posted by MJAldridge6
Urbanengineer
close
- Join DateJun 2013
- LocationOH-IO
iTrader Feedback Score(3)
Liked:1,045 Times in 960 Posts
Quote:
Are you having issues with this thread necromancer?Originally Posted by socalg35x
Quote:
No, just curious to know what were the symptoms of the driveshaft/ujoint going badOriginally Posted by Urbanengineer
That's the price they charge. I was still covered under warranty when I got my new one
Quote:
The most common symptom is a pronounced clicking sound. This is most noticeable when the vehicle is moving slowly while making a sharp turn, such as pulling into a parking space in a parking lot.Originally Posted by socalg35x
A torn boot allows lubricant to leak out (that's bad) and dirty mud-puddle water to get in (that's even worse). This will cause a constant velocity joint to fail.
Daniel B. Martin
Daniel B. Martin
OP is referring to the drive shaft, not the axles.......DanielOriginally Posted by danielbmartin
The most common symptom is a pronounced clicking sound. This is most noticeable when the vehicle is moving slowly while making a sharp turn, such as pulling into a parking space in a parking lot.A torn boot allows lubricant to leak out (that's bad) and dirty mud-puddle water to get in (that's even worse). This will cause a constant velocity joint to fail.
Daniel B. Martin
Quote:
I didn't compose the post properly. My words were addressed to this post...Originally Posted by danoman32
Quote:
MJAldridge6 has an AWD G35 and I interpret "front driveshaft" to mean the axle halfshaft. Is this not right? Maybe I conflated two or more questions and need another cup of coffee!Originally Posted by MJAldridge6 View Post
Daniel B. Martin
Quote:
Daniel B. Martin
He's not talking about the CV Axle Shaft on the passenger side. I too have to replace this part. My front driveshaft needs to be replaced soon, been driving on it for the last 8 months cuz of some clicking noise. I just found out exactly that it is the front driveshaft that needs to be replaced. It's connected to our transmission. I'm going to get it checked out by a specialist next Thursday! Hopefully it's just the u-joint and not the actual shaft. If it is, like on a few of the posts oem is definitely better! Don't mistake an aftermarket shaft for an oem. It will benefit you later on down the line. I've heard due to the aftermarket shaft it causes a headache for some. Like for example someone had replaced it with an after market 1. 3 months later he was back & the cycle went 2 more times. These companies that provide the aftermarket shaft give out 1 yr limited warranties as well as extended warranties. So not worth the buck to keep going through the hassle of changing it out. If anything, in an earlier post there are driveshaft companies that will rebuild it n such but keep in mind that the driveshaft has to unbolt from the spline. Hope this helps!Originally Posted by danielbmartin
I didn't compose the post properly. My words were addressed to this post...MJAldridge6 has an AWD G35 and I interpret "front driveshaft" to mean the axle halfshaft. Is this not right? Maybe I conflated two or more questions and need another cup of coffee!Daniel B. Martin
I got the driveshaft for $720 if anyone ever needs the replacement from the dealer..
