G35 & G37, Coupes & Sedans
Will a set of Tein CS coilovers make ride quieter
Old Oct 4, 2009 | 01:11 AM
LudwigB's Avatar
I currently have the Z spring and shocks and I suspect that is why the ride a bit noisy especially on the freeway and having the 19in wheels are not helping. I wonder if I replace them with a set of Tein Comfort Sport coil overs will quiet down the ride.
Old Oct 4, 2009 | 01:16 AM
parhamm1's Avatar
Short answer: no.
I think camber kits and setting your car as close to 0 all around, with some quality tires (that are known to be quiet) is the best route you can go... This is just my opinion, but I think others will at least partially agree.
Old Oct 4, 2009 | 07:48 AM
EL-EE-ES's Avatar
+1...you have a better chance of having a quieter ride by changing your tires. what tires are you running?
Old Oct 4, 2009 | 11:08 AM
gary c's Avatar
Springs or Coilovers have nothing to do with "noise!" Closely check how your tires are wearing, are the insides of your tires worn? You may need a camber kit and new tires.
Gary
Old Oct 4, 2009 | 11:52 AM
LudwigB's Avatar
Thanks for the responses. The tires are 19' Nitto INVO which do have quite a bit of wear. I'd say there are about 20 -30% treads left. I run 245/40 on the rear and 245/35 on the front.
By the way, which tires would you recommend?
Old Oct 4, 2009 | 01:14 PM
pwebb's Avatar
a quiet ride will most directly be influenced by your tires. a low profile will make it even worse.
stiff suspension can bring about "suspension crash" which resonates the entire cabin, along with bringing out any rattles your car has, and anything loose that can make noise. selecting softer suspension probably wont give you the effect you desire. it will also demand an increase in ride height.
laksjd84
Steering & Suspension
16
Jul 12, 2017 12:22 AM
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
006
Intake & Exhaust
Jul 19, 2015 04:30 PM
mushu
Jul 15, 2015 03:55 PM
