G35 & G37, Coupes & Sedans
Obsessed with Wheel Wells
Old Oct 15, 2009 | 10:02 AM
ga_zander's Avatar
Ho do i make my G's well hug the tire more, i'm talking more to the sides not the top. I really don't like the way the sides flare out away from the tires.
Old Oct 15, 2009 | 10:35 AM
DanielsG's Avatar
get bigger wheels and lower it. thats the only way to eat up wheel well space.
Old Oct 15, 2009 | 11:06 AM
TNC 718's Avatar
Drops don't do anything for the spaces on the sides. What size wheels/tires do you have?
Old Oct 15, 2009 | 12:11 PM
Heist.'s Avatar
Spacers
/thread
Old Oct 15, 2009 | 12:26 PM
GreenGoblin's Avatar
The goblin resurrection
Roll your fenders, go low, get wide wheels, and run camber!
Old Oct 15, 2009 | 12:28 PM
ga_zander's Avatar
i have 20's on
front: 255 9.5
rear: 285 10.5
i talking about having the well hug the wheel, would mud flaps help?
Old Oct 15, 2009 | 12:50 PM
idrive_MD's Avatar
aside from some custom body work, there's nothing you can do about the shape of the wells as they approach the ground...they are the way they are.
Old Oct 16, 2009 | 01:04 AM
gary c's Avatar
Hell yes, mud flaps would help get you LOL
Gary
Old Oct 16, 2009 | 01:20 AM
EL-EE-ES's Avatar
+1...the right way to do it
Old Oct 16, 2009 | 01:41 AM
djwishuwur's Avatar
If you focus on getting wheels with a different offset you may prefer the results. This will give you a chance to make the wheels more flush with the body. You can also play around with wheel diameter and suspension drop to minimize the gap in the wheel well. The gs aren't too far off so I bet you could find the right combination for you. If you don't know where to you start you can always look through the gallery for a look you like and then basing your setup off that.
Old Oct 16, 2009 | 01:49 AM
Dubi2087's Avatar
If you mean the space in front and that back of the tires than you would have to run bigger tires in order to fill those gaps, but if you do run bigger tire YOU WILL RUB. So in your case you can't fill them up..
Xfactor
Dec 1, 2019 12:52 PM
Nicksims13
Oct 15, 2015 01:57 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
atk08
Jul 30, 2015 03:12 PM
