Random Dash lights on
So i have an 05 sedan and ever since it got cold, my hand-break light, the slip light and the VDS traction control light is on. Im sure none of them should be on. Brake obviously not on and defiantly not slipping. I know its just an electrical issue. Have any of you experienced this? Is there an easy fix?
https://g35driver.com/forums/brakes-...light-all.html
https://g35driver.com/forums/g35-sed...vdc+abs+lights
https://g35driver.com/forums/dfw-g35...vdc+abs+lights
https://g35driver.com/forums/g-spot/...vdc+abs+lights
https://g35driver.com/forums/v36-gen...vdc+abs+lights
https://g35driver.com/forums/drivetr...vdc+abs+lights
https://g35driver.com/forums/g35-cou...vdc+abs+lights
https://g35driver.com/forums/brakes-...vdc+abs+lights
https://g35driver.com/forums/florida...vdc+abs+lights
Wow Calvin lol. This actually happened to me after I started my car when I was leaving the JBA dyno. Kinda freaked me out for a sec but then it went back to normal after about a minute
. Guess I should check my brake fluid just to be safe.....
hooters
__________________
La caisse epargne fr | Caisse epargne caisse d'epargne | www caisse epargne
