G35 & G37, Coupes & Sedans
Help with dash board rattling
Old Nov 8, 2009 | 07:16 AM
pch316's Avatar
Hi guys I was driving on the highway today and I've noticed a rattling noise at the dashboard only when my speedometer reaches 70 and up. Have anyone ever experience the same situation. If so, can I get some information on how to repair the problem. Thanks.
Old Nov 8, 2009 | 03:21 PM
pwebb's Avatar
hows your tire balance?
might be a simple fix...
Old Nov 8, 2009 | 04:48 PM
pch316's Avatar
I just got new tires 2 weeks ago and I had it balanced and a wheel alignment. I'm pretty sure it's not comming from the tires. I hear it more from the dashboard. It's more like a ticking sound every time I'm traveling at about 70mph. Under 70 mph is fine, I don't hear the ticking noise. Thanks.
Old Nov 8, 2009 | 05:14 PM
OCG35's Avatar
I had the same problem - but it was rpm dependent not so much speed dependent...
Under heavy acceleration (1st-3rd gear) in high rmp in would tick - coming from the gauge cluster (speedo/tach area)...
I haven't really noticed it lately - but haven't driven it much either... I'm not sure if it went away or not
Old Nov 8, 2009 | 05:29 PM
pch316's Avatar
Did you try to fix it or did you just left it? At what rpm did you hear the ticking? I think mine is also has something to do with the rpm. When I reach 70mph that's when I start to hear a ticking noise at dashboard. Do you think I should leave it or take it to the dealership? Thanks.
Old Nov 8, 2009 | 07:07 PM
OCG35's Avatar
I was never able to determine exactly where it was coming from... fix was/is on the "to do" list... but now that I think about it I don't think it has been happening the last few times I drove the car.
As for rpm, probably around 4-5K in 1st through 3rd gears - while under heavy acceleration... it would go away when I modulate the throttle and decelerate. It was definitely throttle or rmp induced... going past 5K would make it worse so I usually let off throttle when it starts.
Initially it would only happen within first 15 minutes (or so) - after having the car warm up to normal operating temps. But then it seemed to happen well after that.
I don't know what to make of it yet... if it continues, eventually I will isolate and resolve and update here.
Old Nov 11, 2009 | 07:07 PM
pch316's Avatar
Has anyone else experience this same problem regarding rattling or ticking noise by the glove compartment when their speedometer hits around 70mph? Hopefully I can get more opinions and solve this problem. Thanks all.
Old Nov 14, 2009 | 09:53 PM
johnhanson007's Avatar
My whole car rattles super crazy when I hit 88 mph...
Old Nov 14, 2009 | 11:44 PM
snotf's Avatar
count yourself lucky you didnt end up in 1955 as well.
Old Jan 31, 2010 | 01:43 PM
AARONHL's Avatar
I have the same exact problem. It's a weird noise and cannot pinpoint it to anywhere but the glove box, floor, or door panel while driving.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
Learned Hand
Oct 1, 2015 09:02 AM
