G35 & G37, Coupes & Sedans
Heat in the cabin
Old Nov 16, 2009 | 04:22 PM
pch316's Avatar
Heat in the cabin
Hi I don't know why my inside cabin feels pretty hot all the time. Do anyone also experience this problem. Thanks.
Old Nov 16, 2009 | 06:58 PM
EnerOnE's Avatar
Yeah sometimes when i drive the car a lot in traffic. I think it's normal, my last car did the same and it was a lexus.
Old Nov 16, 2009 | 09:00 PM
pch316's Avatar
Cool I thought I had a problem. Thanks.
Old Nov 16, 2009 | 09:34 PM
Mustang5L5's Avatar
Pretty common. Every car i've owned has done it to some degree. Combination of the tranmission and exhaust right under your seat. Heat rises, so over time it tends to come in. Feel your trans hump after driving around a while and you'll feel warmth.
FWD cars don't tend to do it as much as RWD/AWD as the trans hump helps trap rising heat.
Old Nov 16, 2009 | 09:54 PM
PTownG's Avatar
is the car black?
Mine is and it is a freaking hotbox year round even with 20% tint
Old Nov 17, 2009 | 01:19 AM
pfarmer's Avatar
I think it comes down to if you have a sidewinder setup or not. Keep in mind that your driveshaft tunnel is often used for exhaust in a FWD car.
Old Nov 17, 2009 | 03:16 AM
Skaterbasist's Avatar
Retired SuperMod
If you are referring to heat coming out of the vents during driving, just make sure the vents are closed on the AC control.
Old Nov 17, 2009 | 04:14 AM
pfarmer's Avatar
Toss her out if heat is a problem. My cabin is a little cool at the moment.
Old Nov 17, 2009 | 04:34 AM
ntrinsik's Avatar
Have the heated seats on by mistake? I did that once.. didn't even notice they were on.
Old Nov 17, 2009 | 09:34 AM
OBG3506's Avatar
change the vents to recirc, this usually stop the warm air from coming thru.
Old Nov 17, 2009 | 11:23 AM
jaysoonii's Avatar
Hey, try to turn on your AC and switch from HOT to COLD, than turn your AC off again.
Old Nov 17, 2009 | 12:01 PM
BloodlineG's Avatar
^thats the fix.. that happens to me all the time.
Old Nov 19, 2009 | 12:14 PM
Morovasa's Avatar
Yea happens to most cars... heat shield can only hold off so much heat.
Nothing to worry about
Old Nov 20, 2009 | 09:37 PM
Bruin003's Avatar
Mine does that after I use it to defrost. Just open the sunroof using the tilt..and take your air off recirculate...it'll cool down.
KruZZe
Feb 27, 2023 05:04 PM
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
hrdwirk1
Oct 2, 2015 06:34 PM
