G35 & G37, Coupes & Sedans
Anyone know if our G's can take a larger oil filter?
Old Dec 27, 2009 | 11:37 PM
geronimomoe's Avatar
Like everyone implied, different (larger) filters can fit. HOWEVER, the thing that bugs me is how about the bypass valve pressure? If it's different what (if any) effect that will have on the engine.
If you think about it, wouldn't it be easier from the manufacturer's (Nissan/Infiniti) point of view if they standardized on the same oil filter for all their vehicles? Since they don't, there probably is a reason. So my opinion is to stick with either OEM OR the aftermarket equivalent to the OEM designed for your vehicle...
Old Dec 27, 2009 | 11:50 PM
PTownG's Avatar
Oye.
A larger oil filter does not reduce engine oil pressure.
I'll refrain from saying anyting more that some might take as offensive.
Old Dec 28, 2009 | 12:19 AM
Jeff92se's Avatar
Red Card Crew
I've said this about 13 times. The maxima and G filters are spec'd out identical or almost identical. They made the G/Z unit tiny for space reasons or something. I can't remember other than thinking it was a retarded reason.
You guys actually think the VQ35 in the Maxima or M series are all the diff than the one in our Gs? In oil requirement terms, they ain't.
Old Dec 28, 2009 | 12:40 AM
gary c's Avatar
Originally Posted by PTownG
Oye.
If a larger oil filter reduced oil pressure can you imagine what an "Oil Cooler" would do? The first time I bought a K&N filter for my G I looked at it and asked the clerk, "Where's the rest of it?" I just started using the K&N 1010 which is slightly larger. Ordered 5 today on line for $10.85, shipping was free for purchases over $50....next order 2K11.
Gary
Old Dec 28, 2009 | 12:53 AM
gary c's Avatar
Don't be bugged by something so simple. If you go to a K&N site it lists the bypass valve pressures, the one listed for the G/Z and the M are exactly the same....no worries!
Gary
Old Dec 28, 2009 | 08:39 PM
BuckeyeInMI's Avatar
Originally Posted by SwivelHips
Amsoil EAO13 or Wix 51356 here (larger size)
Wix makes the Napa Gold line of filters. I use the one for the M45 (1356). http://www.napafilters.com/filterloo....asp?Part=1356
Old Dec 31, 2009 | 09:30 AM
Gary
For K&N they may be the same
If they were the same with Infiniti, then why would they (from a business point of view) want to stock/purchase 2 different parts that meet the same specs? Doesn't make sense.
Old Jan 4, 2010 | 10:24 AM
MidnightG35X's Avatar
I use PureONE 14610, little big larger than the spec'd 14612. No problems in 40k miles.
g.spot
May 9, 2016 10:54 PM
BradMD_96
Oct 6, 2015 09:31 AM
vamarris
Sep 26, 2015 12:56 PM
sullivan72
Sep 22, 2015 11:39 PM
