At what psi do the TPS kick in and throws a warning light? (!)
One thing I would look at is that there is a recall on some of these TPMS units (I think on FX) due to corrosion of the nut. It may be worth while to look at ours as well to make sure it is limited to just the FX (I think it was the FX) especially if they have ever been replaced. The problem is that when the nut fails you rapidly lose all pressure, not a good thing.
good grief - most responses are wrong (where do you guys come up with your response in posts? guessing?)
25 for sedan - 28 for coupe
http://www.infiniti-techinfo.com/ref...finiti-G35.pdf
I knew I was right (at least for the car I drive):
https://g35driver.com/forums/4714326-post5.html
mjfenix
07-17-2015 02:07 PM
