G35 & G37, Coupes & Sedans
Windows Roll Key Feature..
Old Apr 11, 2010 | 01:37 PM
DaVinci87x's Avatar
Hey there, i own a G35 Coupe 06 and recently found out that by holding the key in the door cylinder towards lock will make your windows roll up. Now here is the thing my driver side window wont do it. Keeping in mind my windows have no issues at all since they roll down with the Key Fob and roll up by the windows switch. Anybody has an idea of what could possibly be happening ?? Thanx in advance.DOMO
Old Apr 11, 2010 | 04:38 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Not sure why your driver's window won't do it with the key. Mine does.
Old Apr 11, 2010 | 06:39 PM
the_sedan's Avatar
maybe re-time the window motor? both of mine work together.....
Old Apr 11, 2010 | 07:05 PM
dave's Avatar
Will it roll down with the key? If not, a previous owner may have disconnected it trying to keep people from breaking in.
Old Apr 12, 2010 | 06:56 AM
^ Good insight right there.
Or maybe it was broken when somebody broke into it that way?
Does it roll down with the key in the unlock position in the door?
Old Apr 12, 2010 | 02:52 PM
felixsc300's Avatar
Windows on '06+ can be rolled up via remote...I'm jealous.
Old Apr 12, 2010 | 05:48 PM
^ where'd you get that idea?
Actually with an add-on module all years can.
Old Apr 12, 2010 | 07:05 PM
sTeadFasT96's Avatar
Here's the thing. Mine does the same thing but I think the dealership said it may have to deal with timing or osmething.
The issue with my driver side window is that if it is FULLY down, if I just flick the switch for auto roll up or if I do the roll up via key in the door, it'll try to roll up for maybe 1/2 an inch then it'll roll back down as if there was something in the way.
Try rolling it down only partially and not all the way down, then roll it up using the key in the door and see if it still doesn't roll up.
Old Apr 13, 2010 | 11:02 PM
carsontl's Avatar
http://www.kptechnologies.com/produc...el=G35%20Coupe
KP Technologies ITEM#NM20 $49.99
WINDOW ROLL-UP MODULE (NISSAN/INFINITI)
The window roll-up module easily installs inside your vehicle's door panel and allows you to roll the windows up by pressing the 'LOCK' button twice on your key FOB remote.
Key Features:*
• Vent windows capability
• Auto door locking
http://www.kptechnologies.com/docs/N...stallation.pdf
Old Apr 14, 2010 | 05:19 PM
SxSkyLinexS's Avatar
they only roll up with the module
whered u hear they do from factory?
Old Apr 14, 2010 | 05:38 PM
PublicEnemy's Avatar
No they don't.
Old Apr 15, 2010 | 04:08 PM
KPierson's Avatar
Does the "one touch" feature work on the drivers window? It sounds like you need to relearn the anti pinch function. If the anti pinch system isn't programmed you won't be able to one touch or raise the windows with the key in the door.
If the wire was disconnected inside the door neither windows would go down. I actually recomend cutting that wire to prevent thiefs from exploiting that little security flaw.
The KPtechnologies (www.KPtechnologies.com) NM20 has been the standard for adding remote window up to Gs and Zs for the past 5 years!
Old Apr 17, 2010 | 05:39 PM
rhoward15's Avatar
same thing with me
Dallsinghjr1
Sep 17, 2023 11:25 AM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
dcsbh1
Oct 1, 2015 03:15 PM
NyCrAzY
Oct 1, 2015 09:19 AM
