G35 & G37, Coupes & Sedans
Raspy Exhaust
Old Apr 25, 2010 | 11:50 PM
Craig Ambrose's Avatar
Raspy Exhaust
I have a modified Borla Muffler for a Camaro...Its set in same place as stock muffler..3 in. mid pip, no resonator...and just put on test pipes today. Its sounds great but getting on it 3k rpm and higher it gets a lil raspy. Any cure? thanks
Old Apr 25, 2010 | 11:52 PM
elayman's Avatar
swap test pipes for resonated ones or HFCs
JIle342's Avatar
get rid of the test pipes
Old Apr 26, 2010 | 12:38 AM
Jairen's Avatar
I say stick with test pipes, but go with ART's.
Rasp will occur with test pipes regardless. You will have to add a resonator somewhere to help tone down the rasp. You best bet is to get the Motordyne XYZ with resonator to help with the rasp. Otherwise, get a resonator or pre-muffler put in place.
Are you still using your stock y-pipe? Since you now have test pipes, I'd bet the diameter of the test pipes and the y-pipe don't match.
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
Albanian122
Sep 12, 2015 04:02 PM
