G35 & G37, Coupes & Sedans
gettin a newer g
Old Apr 26, 2010 | 06:12 PM
o4g35coupe's Avatar
gettin a newer g
I currently have an 04 coupe and am thinking about trading it in for a newer like 07 maybe and 08 g37 depending on prices of course. My question is I have rims on my 04 and want to know if the lug pattern is the same for the newer models and also the offset as I dont want to get rims. Also is the 08 that much better than the 07. Hope this was the right place to put this. Thanks
Old Apr 26, 2010 | 06:14 PM
Locksmith's Avatar
Lug pattern is the same but offsets might be a little different.
Old Apr 26, 2010 | 06:34 PM
davidxu's Avatar
post it in the V36 section
4DGS's Avatar
The 07 coupe isn't a 37 it's still a 35 with a DE engine. Not sure what you're asking.
Are you going to another coupe? If so, the g37 (2008) is a lot quicker but the offsets are higher. The 07 will be exactly the same as your 04 (aside from the rev up engine, but it's still the same engine)
What are the widths and offsets of your wheels?
Old Apr 26, 2010 | 07:08 PM
o4g35coupe's Avatar
yeah I know the 07 is still g35 just wondering if its worth changing to 07 or just do an 08 main reason want a newer is so I have a warranty as when I bought my car it had a warranty but the company went out of business. Thats a whole different story. Not sure on the rims as they came with the car think the rears 20x10 and fronts 20x8.5 or 9 not sure. They are 275 in the rear and 255 up front. They sit flush with fenders. and yeah I want to stay with the coupe love the car.
What do you mean the offsets are higher for 08 4dgs. Thanks for help
Old Apr 26, 2010 | 07:18 PM
4DGS's Avatar
I suggest making the jump to a G37 then.
The G37 uses a higher offset to be flush then the first gen G does. Lets say your offset on those wheels is +22 and they sit pretty flush, you would need a higher offset to get that kind of flushness, if you put the +22 on the G37 it will poke a little and you might have to run smaller tires.
Find out the offset though and I can give you a better idea, do you plan on dropping the new car? (are you dropped now)
Old Apr 26, 2010 | 07:26 PM
o4g35coupe's Avatar
no not dropped now and prolly wont drop the new car roads suck in Delaware plus already have a truck on air ride so dont need another low vehicle. How can I find out the offset of my rims.
Old Apr 26, 2010 | 07:37 PM
saywat?'s Avatar
yea its pretty weird that they made it like that. i believe the g37 is like 40-50 offset buts its pretty darn flush stock lol fkn g35 stock offset is rediculous
Old Apr 26, 2010 | 08:05 PM
4DGS's Avatar
Dude, I'm an inch off the ground and live in Canada!
Find out the exact offset and I'll tell you if they'll fit the 37.
Old Apr 26, 2010 | 09:09 PM
o4g35coupe's Avatar
heres a link to them with all the info at the bottom
/www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialP artNumber=108042S3579SDCPSL&wheelMake=Avarus&wheel Model=AV1&wheelFinish=SDC+w%2FPolished+Stainless+L ip&showRear=yes&selectedRear=105012S3579SDCPSL&aut oMake=Infiniti&autoModel=G35+Coupe&autoYear=2004&a utoModClar=Base+Model&filterSize=All&filterFinish= All&filterSpecial=false&filterBrand=All&filterNew= All&sort=Brand
Old Apr 27, 2010 | 02:06 PM
o4g35coupe's Avatar
here ya go 4dgs
offset
Front is 35mm 20x8.5
Rear +35mm 20x10.5
Backspacing
Front 6.18
Rear 7.16
So will they fit right on a g37 Thanks again
Old Apr 27, 2010 | 05:47 PM
4DGS's Avatar
At stock height, you'll be fine.
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Jeff469
Sep 25, 2015 09:28 AM
Joe Gargano
Sep 18, 2015 11:17 AM
