G35 & G37, Coupes & Sedans
Low / No Oil Consumption Gs?
Old May 4, 2010 | 01:53 AM
Tangerine's Avatar
My G burns oil, tried almost every different oil there is. Conventional, synthetic blend, full synthetic, amsoil, castrol, german castrol, mobil1 etc. My valve covers are new, not sure on other's conditions since oil do tend to poll up on the spark plug holes. Never had any car consume oil except for this car.
Old May 4, 2010 | 06:48 AM
Blue Dream's Avatar
I drove ttrank's car solo
Originally Posted by Braintree
I have around 90K miles and consume around 1/2 cup of oil every 3-4K miles. Oil is changed every 8-10K and the filter (Pure One only) is changed every 3-4K miles. I use Mobil 1 extended performance, or Castrol Edge or the new Pennzoil Ultra.
If history is repeats itself, this will be the 5th car I've owned that exceeds 350K miles (I've owned 2 that exceed 400K before they were sold)... oil changes with descent oil is just one of several critical variables in the life of any car.
How do you change the filter and not the oil? Do you have lightning quick ninja reflexes to get the new one on before the oil drains?
Old May 4, 2010 | 09:23 AM
K Dub's Avatar
Originally Posted by kennymo
yea i know its not "normal" but as far as the G, does that sound normal?
and just to make sure. 5 qts is the correct amount that im supposed to be putting in right?
Sure it's normal. Normal for Mobil 1 anyway...put in a real oil and you won't burn even half as much.
Old May 4, 2010 | 10:45 AM
gary c's Avatar
What a bunch a B.S.
I can't imagine where you guys get your opinions about engine oil. Using synthetic oil is far better than dino oil, runs cooler and cleaner. Synthetic oil regardless of brand doesn't cause oil consumption. I used Mobil1 in my last Z, didn't use a drop between changes at 125K miles....and it's still on the street. And it's not advisable to go back to dino oil after using synthetic, thought you like to know!
Old May 4, 2010 | 11:25 AM
OKStateG35's Avatar
Mine burns 1/4 quart or less between oil changes (3,500-4,000 miles). Not even sure if it's actually 'burning' that or if it's just due to the fact that I'm using the slightly larger M45 filter. I guess I should get in the habit of checking the level right after an oil change, but I always forget.
Old May 4, 2010 | 11:27 AM
OKStateG35's Avatar
Originally Posted by jibberjabbers
Did you read what I posted it? My G burns no oil at the moment. Knock on wood. And it's a 6mt rev-up. I change it every 3700 miles though and I don't use full synthetic.
I think it's kind of funny that you're one of the guys constantly complaining about what a crappy car the G is, yet yours doesn't even suffer from the worst problem these cars have.
Old May 4, 2010 | 06:16 PM
jibberjabbers's Avatar
I don't have problems with Oil consumption.. Knock on wood. But then again, my car has barely 10k miles and this isn't my daily driver.
I did have problems with the following:
1) At low speed, the Tranny make some type of grinding sound.
- Fixed thru warranty
2) Rear was making some strange popping clanking noise
- Fixed thru warranty - Cause - Loose axle bolt, re-torqued and it's all good
3) Creaking sound coming from the dash,
- Not yet fixed, "supposedly Normal" according to this forum, yet this is a TSB on it.
4) Creaking sound coming from rear seat
- Not yet fixed. TSB is issued on this
5) Horrible uneven tire wear, aligned to spec by Nissan and then again by Performance Plus in LB. Problems still recurs.
- Front driver side - Outer tire wear, horrible feathering
- Front passenger side - feathering, not bad is driver side
- Both Rear - feathering inside
6) Creaking noise from the sunroof.
- Not fixed yet. TSB issued.
7) Right side, rear speaker
- popping noise?? Static?
I might take the car in when Infiniti issues a recall on the air bags. I'll let them take a look at all this..
But it's nice to see that you're happy that your car burns oil. If that was my car, I would be really pissed. Maybe when it's out of warranty it'll show signs of oil consumption.
Old May 4, 2010 | 06:34 PM
marcinr's Avatar
20 Year Member
My 2003 doesn't burn very much oil. I check oil every few weeks, and it's usually almost exactly at the level I filled it. I think I might have to drive like 10k miles before I lost a quart.
Originally Posted by z-man
I have a '06 G35X A/T with 50k miles running Mobil 1 synthetic, and burn about 1 qt per 3500 miles. I have seen a lot of posts here that this is 'normal' for this engine, and is certainly not as severe as the cars with true consumption problems in the 1qt per 700-1000 miles range.
My question is are there drivers here who have 0 or very minimal oil consumption? Is it even possible for this engine?
Old May 4, 2010 | 06:40 PM
Ginevan's Avatar
I"m using M1 Full Synthetic 10/30 in mine. I've been getting people telling me it has great protection, however it breaks down right around 3K miles, so if your **** about changing your oil on time, then yay, use M1, but if not, then don't.
However, next oil change I'll try using... Castrol? I'll see what I get on the Maxima.
Oil filter drain hole is higher than the oil pan, therefore it doesn't drain the entire system. Did this on the mother's Maxima w/ a VQ35DE when a fram toughguard had a bad seal. Thank god I started the car up to check for leaks.
To the OP, my mother's 05 Maxima VQ35DE 88K consumes about 1.5 every 3500 on M1 10W30 Full Synthetic w/ Fram filters. About 80/20 split on city/highway driving.
My 04 Brembo coupe 82K consumes about .75 every 3K on M1 10W30 Full Synthetic w/ M1 filters. About 50/50 split on city/highway driving.
EDIT: I also just put on TP's and I will see if the myth of TP's leading to greater oil consumption is true.
Old May 4, 2010 | 06:43 PM
Ginevan's Avatar
It's actually harmful. This causes the oil to become extremely thick and "sludgy"
Going Dino to Synthetic is fine, but if you go from Synthetic to Dino you MUST do a full engine flush.
Old May 4, 2010 | 06:47 PM
I asked the very same question.... I said it must have been messy as hell... But someone replied that the car has some type of valve that prevents oil from leaking when the drain bolt isn't removed...
Can anyone verify this?
Originally Posted by Jeff92se
I believe the engine block features a check valve that prevents the oil from draining when you take the filter off.
Old May 4, 2010 | 06:49 PM
Ginevan's Avatar
Posted above that the oil filter drain hole is higher than the oil pan.
Old May 4, 2010 | 06:54 PM
Even so, oil still leaks out.... Changing the oil filter w/o draining the oil is messy if you try to quickly put the filter back in.
But, if you just remove the filter, and let some oil drain out, wait for the pouring to turn into drips and then put it back in, then it will be less messy.
Even if you do it that way, you're going to be missing a good amount of oil.
So how much oil drains out if you just remove the filter?
Old May 4, 2010 | 06:56 PM
Ginevan's Avatar
False.
Only the amount of oil that was in the oil filter will drain out. Try this next time you change your oil. Let me go look under my car to double check if the G35 Oil filter vertical placement is similar to the Maxima.
EDIT: Looks like I was wrong. Oil filter placement on the G is infact lower than the Maxima. Check valve theory could be possible... I'll test this theory next time I change my oil (just changed it this morning )
Old May 4, 2010 | 07:05 PM
  #30
I change my own oil all the time and I know that a good amount of oil leaks out of the filter area.. But then again, the drain bolt is removed at the same time.
Next time, I'll remove the filter 1st just to see what happens.
