G35 & G37, Coupes & Sedans
Removing Wood Trim
Old Jul 9, 2010 | 11:02 AM
AmeRikaZmoStWaNteD's Avatar
Removing Wood Trim
I had a quick question.
The g35 I got is clean but it had wood trim on the inside. I was wondering is there a way to take it off?
Old Jul 9, 2010 | 11:13 AM
kvangil's Avatar
It's just adhesive, so you should be able to tear it off. Once it's off, not sure what's best to remove the glue though. However, nail polish remover has worked for me in the past.
Old Jul 9, 2010 | 12:05 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Hair dryer or heat gun will help take it off, then use Goo Gone to remove what's left of the adhesive.
Where possible - center console at least - remove the parts from the car before doing this.
Old Jul 9, 2010 | 12:13 PM
Is it necessary to remove the parts?
Like does it cause damage if I don't
Old Jul 9, 2010 | 04:28 PM
jutn35's Avatar
G35 Coupe
remove asap, that trim looks cheap. replace with aluminum !
Old Jul 12, 2010 | 12:14 AM
Osa713's Avatar
I would remove the console pieces first, its easier to work with the pieces off of the car. But a hair dryer and goo gone should do the trick. But no one knows how that glue is going to look. its been on there for at least 6-7 years.
Old Jul 12, 2010 | 12:32 AM
davidxu's Avatar
yeah, you have to remove the parts. You dont want a liquid and electrical stuff coming together.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Video Share
Jan 31, 2017 04:00 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
dcsbh1
Oct 1, 2015 03:15 PM
