How do you check over a used G35 before buying?
I'm going to be driving a few hours this weekend to check out (and hopefully pick one up) a couple 2005-2006 G35's and a couple Maximas (still can't make up my mind, I know - strange?!
I searched for this but couldn't find it - is there a list of things that can be easily checked for on the G35? I've read to check the inside of the tail pipes to see if they're really greasy or dirty, but that's about all my research has given me so far. Any links or tips?
Thanks!
)I searched for this but couldn't find it - is there a list of things that can be easily checked for on the G35? I've read to check the inside of the tail pipes to see if they're really greasy or dirty, but that's about all my research has given me so far. Any links or tips?
Thanks!
Thank you!
Besides the appearance of the car, test drive the car with the stereo off. When you turn on the car, check for any strange start-up noises. Also most G's with over 70k would need to have the valve cover replaced because of oil leaking onto the plugs. And that alone is a 700+ repair.
Listen to any creaking, squeaking noises. That would be a sign of bad compression bushings which there is a TSB out for it. Most likely the car is out of warranty and you would have to shell out another 300+ to get those replaced.
Check to see if the windows roll up and down smoothly, sunroof works, and check to see if the door locks work when you press the buttons. These are stuff the craps out most of the time in our cars. (Google G35 window motor fail, door lock fail, etc etc.).
Check the seats for any tears, rips etc etc. Our leather seat are prone to ripping especially near the area where the leather meets the plastic panels on the outer bottom edge.
Also check the oil level as a few G's (mostly 05+ 6mt's) but even some 03+ automatics have had their engine replaced due to oil consumption. So make sure the oil level is good before you test drive the car.
You don't want a car that looks good on the outside, but ends up in the shop most of the time.
I would definitely suggest taking it to an Infiniti dealership. It was $50 bucks at my dealership, but completely worth it when considering dropping a few grand on a car. They go over pretty much anything, they'll check when it last came through the dealership for fluid changes, they can tell you if the compression rod bushings are shot, etc.. Beyond that, like stated above, try to figure out if it is consuming oil.
also if u not gonna go to a infiniti dealership give 1 a call with the VIN # etc and they can tell u what options it has and if it has been taken care of well through Infiniti/Nissan Dealers.
I'm just thinking that, if you're buying a car from an Infiniti dealer, there's really nothing you can do except take it to an independent mechanic, who may or may not know something about G35's
You can also get an Autocheck report and see if there's any discrepancies between it and the Carfax. When I bought my car used at the dealer I forgot to ask for the service records, it was used as a courtesy shuttle for a while, and was mechanically sound so I didn't really give it much thought.
Even if you get a CarFax, I would still check it over really well for any signs of repair. I bought mine Certified Preowned from Infiniti with a clean CarFax and I still noticed months later that the rear bumper has been repainted. It's something I could have noticed before buying if I would have looked closer for overspray.
The main things I would check are bushings, oil level, all switches, and the hood hinges. My hood made a popping noise when I opened it which is the first sign of hinges going bad. I found out later that it's very common on these cars and can be prevented if you catch it early.
