G35 & G37, Coupes & Sedans
installing 5/16 plenum spacer.
Old Aug 31, 2010 | 02:42 AM
hL.'s Avatar
hL.
So I'm installing the plenum spacer on my g in a couple days. I noticed motordyne instructions has certain torque specifications on some bolts (40 inlb - 100 inlb).
For all those who have done this installation, did you guys actually use a torque wrench to meet these specs? Or do you think my own judgment will suffice?
I just don't want to spend another 200 bucks on a torque wrench but I also don't want anything to go wrong with the engine because of a loose bolt. haha.
Old Aug 31, 2010 | 03:10 AM
Jairen's Avatar
I used a nut driver as per instruction and worked out fine.
Old Aug 31, 2010 | 04:24 AM
Blue Dream's Avatar
I drove ttrank's car solo
Same here. I have installed and removed several spacers and used this method every time with no issues.
Old Aug 31, 2010 | 10:44 AM
Tollboothwilley's Avatar
i never use a torque wrench - i do it by hand with no problems. You need to realize that when its tight you're good and not to keep torquing it though. Easy to cause problems by over-wrenching these bolts.
Go over all the bolts multiple times to make sure they are all snug to the same level and you'll be fine.
Old Aug 31, 2010 | 11:00 AM
Swivel's Avatar
Moderator
Yup, I use this method or even a small (1/4" drive) ratchet and like willey says, tighten in sequence by small increments and stop when it's tight!
Old Aug 31, 2010 | 11:04 AM
tragedycat's Avatar
I've used a torque wrench every time. If I couldn't procure one I'd probably try the methods the guy above said, but if you can borrow one from someone or somewhere, I'd go that route to be safe.
Old Aug 31, 2010 | 11:56 AM
gary c's Avatar
I went out and bought a torque wrench after reading the instructions from Motordyne. I also use it when reinstalling my wheels but "snug" is probably good enough in both areas.... however it never hurts to have the "right tool!"
Gary
Old Aug 31, 2010 | 12:53 PM
305G35's Avatar
just tighten it down snug. don't muscle it too much and you'll be fine. the important thing is to not overcompress the spacer.
Old Aug 31, 2010 | 02:46 PM
hL.'s Avatar
hL.
thanks for the help! I managed to borrow one from a buddy of mine.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
G35VSHNG37
Oct 25, 2015 08:43 PM
IkonG35
Aug 10, 2015 09:33 AM
deathsupport
Canada
Aug 2, 2015 10:13 AM
