G35 & G37, Coupes & Sedans
Buying Oil at AutoZone
Old Sep 15, 2010 | 02:36 PM
  #31
thescreensavers's Avatar
Mr.202?
Originally Posted by Jeff92se
Tell me, what does the VQ to a filter that makes the Fram so unsuitable for it but fine for others?
*Jeff knows the base Fram is not made well, that isn't the question*
Meh idk what he is trying to make saying only not to use it on the VQ?
I would not use it on any Engines Period.
Old Sep 15, 2010 | 02:51 PM
  #32
saywat?'s Avatar
I'm curious how you do this. Do you just drain the oil and put it back into the car after you change the filter?
Seems like an interesting concept.
sounds like a waste of time and messy imo lol
Old Sep 15, 2010 | 02:52 PM
  #33
Mr.202?
^ Yep, I would just invest in a filter that can do 10k miles OCI
the bosch distance plus is great and Advance Auto Gives that out. with Syntec for 26.99
But Look into other filters, that can to 8k OCI's
Old Sep 15, 2010 | 02:59 PM
  #34
OKStateG35's Avatar
Is that for the Edge?
I believe so. I started buying Edge a couple of oil changes ago and I could have sworn it was right at $26. Maybe I'm wrong though. I'll have to check next time I'm at WalFart. I think it's been on sale at least one time when I bought it.
Old Sep 15, 2010 | 06:55 PM
  #35
Infiniti Chica's Avatar
It takes me around 2-3 minutes to do, then you simply wash your hands, and that's it. An oil change takes much longer, costs more and is messier overall.
Old Sep 15, 2010 | 06:58 PM
  #36
Swivel's Avatar
Moderator
Amsoil EA also, but I did have an issue with one leaking once. Could have been my error. I switched back to Wix and change halfway.
Old Sep 15, 2010 | 07:09 PM
  #37
Neu Era's Avatar
Try Advance Auto, they always have specials on oil. Just got 5 qts of 5w30 Castrol Edge fully synthetic and a K&N filter for $25. One hell of a deal.
Old Sep 16, 2010 | 01:58 PM
  #38
Jeff92se's Avatar
Red Card Crew
Your oil won't run out if you just take off the oil filter.
Old Sep 16, 2010 | 02:04 PM
  #39
Blue Dream's Avatar
I drove ttrank's car solo
Old Sep 16, 2010 | 02:14 PM
  #40
saywat?'s Avatar
yea it probably wont all run out but alot of it sure would rush out lol
Old Sep 16, 2010 | 02:53 PM
  #41
OKStateG35's Avatar
This has been discussed before and it seems like people have said there is some sort of check valve that allows you to change the filter without losing all the oil.
Old Sep 16, 2010 | 03:04 PM
  #42
Mr.202?
^ oh? I never knew that. I know the filters have them.
Old Sep 16, 2010 | 04:19 PM
  #43
blazeplacid's Avatar
yeah, you will only lose whats in the filter and a alittle bit of oil.
id say another 1/2 quart would probably be enough
but to me it seems kinda worthless, might as well drain the oil and swap the filter. its cheap enough
Old Sep 16, 2010 | 04:22 PM
  #44
Jeff92se's Avatar
Red Card Crew
You sure of that? For one, the filter is actually higher than the bottom of the oil pan if I remember correctly. Not to mention the check valve which I think is in the block. And the fact the Amsoil recommends an filter change while keeping the same oil.
Old Sep 16, 2010 | 04:29 PM
  #45
saywat?'s Avatar
^^not to sure since people are now mentioning theres some valve that reduces the amount of oil that u lacked to mention
