G35 & G37, Coupes & Sedans
G35 Blown engine?
Old Sep 17, 2010 | 11:16 PM
Shocka82's Avatar
G35 Blown engine?
So here I was about to hit the quarter mile to get times for the forums and i got to the line, hit the gas and half way (into 3rd gear) into it my turbo stopped for 5 seconds and the engine just stopped immediately. I saw a huge puss of white smoke meaning antifreeze/water I would assume meaning head gasket blown. But if that was the case, my engine would have clicked a few times if I tried to start it. Now when I crank the ignition it only gives a click or a slight starter movement and stops. does that mean my engine has been locked up??? Appreciate the help!
Old Sep 18, 2010 | 12:19 AM
HotRodG35's Avatar
A few possibilities. If coolant filled cylinder than it could be hydrolocked and caused connecting rod to bend.
Remove spark plugs and see if crankshaft can be rotated by hand without binding. If engine doesn't rotate than it could be siezed from bearings or bent rod. Bent connecting rod will sometimes allow engine to rotate in opposite direction from normal.
If engine rotates freely than check oil for coolant, inspect cylinders for sign of coolant with spark plugs removed. If engine coolant in cylinders or oil than headgasket blown or head cracked.
Old Sep 18, 2010 | 12:26 AM
silver g's Avatar
You on stock block?
Old Sep 18, 2010 | 12:28 AM
HotRodG35's Avatar
Full built long block using rev up OEM block
Old Sep 18, 2010 | 09:10 AM
Shocka82's Avatar
Yea so I assume its locked somehow, think the pressure from the turbo did it or was it just its time? I have a warrenty also so i need to remove my turbo and all haha. thanks any other help would be useful like if i repair it w/o warrenty, about how much would it be for a head gaskey, or bent rod or whatever
Old Sep 18, 2010 | 09:38 PM
Mustang5L5's Avatar
How do you have a warranty on a fully built block, but yet have to remove the turbo? Was the engine designed to handle the extra boost?
Pull your spark plugs and try to turn the engine over. If it still doesn't go, you more than likely blew something internally.
How much depends on the extent of the damage. Honestly, there is not much we can tell you from here since we can't see the car. I've seen guys crack their blocks in half (various other vehicle types) at the track from carnage...and not find out about it until they get the car home and tear into it.
Old Sep 19, 2010 | 02:24 AM
Shocka82's Avatar
Mustang: I think you got a little confused with the replies. I have stock motor/trans on 8PSI and I have an extended warranty with a third party. I think hot rod was talking about his block when he said fully built to reply to silverg. Anyways, I will be getting a new engine paid for by the warranty company and hopefully it will have alot less miles than mine did
(68000). Maybe the shop will build it up a little with forged pistons or something. Good thing I bought that optional extended warranty
Old Sep 19, 2010 | 11:06 AM
Mustang5L5's Avatar
I did get confused...sorry my bad.
Old Dec 20, 2021 | 09:07 AM
gg35vq's Avatar
g35
did you figure out the problem same thing I’m going through right now white smoke loud bang….no start just no crank just a click and my cam and crank shaft sensors code popped up
Old Jan 8, 2022 | 03:46 PM
KennyS's Avatar
2004 G35 red,3.5
Moderator EDIT: Banned for botting for some salvage yard...
KARMA_G35
Jan 22, 2018 09:52 AM
SejRamkas
24
Aug 4, 2017 02:20 PM
g3fyve
Oct 28, 2015 09:17 AM
Heero
Dec 3, 2008 08:26 PM
Airey
13
Nov 27, 2002 09:16 PM
