G35 & G37, Coupes & Sedans
Wheel thumping sound...any ideas?
Old Dec 2, 2010 | 06:57 PM
speedgeek's Avatar
Hi,
I have a 2005 G35 coupe 6mt with about 70,000 miles on it. Ive started to get a thumping sound, like a tire flat spot that goes with the speed of the car. I just got new tires, balance & align and the sound is still there. It gets louder when I corner the car. Any ideas?
Thanks!
Old Dec 3, 2010 | 02:12 PM
marcinr's Avatar
20 Year Member
Things that cause thumping sounds and get worse when cornering:
- Bad wheel bearings (those these usually make a whining sound). Jack up each wheel, grab it firmly, and try give it a few strong tugs in various directions, any play means bearings, or suspension, is loose.
- CV joints. Jack up your rear wheels, feel around on the rubber covers surrounding the axle CV joints. If any of the rubber boots are broken and you can feel the grease inside with your finger, or even worse, if you can feel sand or it's bone dry, you've probably worn out the CV joint.
Less likely:
- Warped, rubbing brake rotor
- Crooked wheel
Old Dec 4, 2010 | 01:05 AM
speedgeek's Avatar
Thanks!
Thank You! Great info , I'll check this tomorrow.
Old Dec 4, 2010 | 12:13 PM
GarGamel's Avatar
Are you running stock wheels? I had the same issue after I got new tires installed on my volk racing wheels. Come to find out the shop had put two hub rings on the one wheel. After removing one, noise went away. Good luck bro.
Old Dec 6, 2010 | 04:09 PM
Gdirty5Az's Avatar
Like what Marcinr was saying. Jack the car up and wiggle the wheel if its loose it could also be your wheel hub.
Old Dec 6, 2010 | 04:16 PM
speedgeek's Avatar
Update
Update - Brought it to the dealer this morning, it was a hub bearing, amazingly covered under warranty (400 miles from end of warr) woot!
Thanks guys for all the helpful info..you nailed the cause.
Old Dec 6, 2010 | 05:40 PM
gannicus's Avatar
so they the dealship can fix the problem cause i have the same thing
Old Dec 7, 2010 | 05:15 PM
marcinr's Avatar
20 Year Member
Glad it worked out ok. Wheel bearings are a wear item an this does occasionally happen, even if it wasn't covered by warranty, this is an easy repair and a relatively inexpensive part.
Old Dec 8, 2010 | 08:40 PM
impulse_x's Avatar
this is good to know.. thanks guys
Old Dec 8, 2010 | 08:52 PM
gary c's Avatar
Issue solved, I would have suspected a tire first. On a previous Nissan I had a tire tread break and it was making the thumping noise you described. Glad you found out what it was got it fixed for freeeeeeeeee....
Gary
Old Jul 26, 2011 | 09:55 AM
Heckrat's Avatar
Just started happening to me this morning. How much did the dealership charge you? I have a warranty but not sure if that's covered.
Old Jul 26, 2011 | 12:19 PM
GXXXV X's Avatar
it happened to me right after i painted my wheels and i checked to see what it was and i discovered that i had not tightened the lug nuts on one of the wheels...
Old Jul 26, 2011 | 03:36 PM
Heckrat's Avatar
Hmm.. I painted my wheels not too long ago, I did notice some shake around 70mph+ but it wasn't making the noise it is now. It sounds as if I have a flat tire but all my tires are fine. I will have to make sure they are all tight before I drive home today.
Xfactor
Dec 1, 2019 12:52 PM
MsFitFern
Aug 9, 2015 02:58 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
rping
Jul 26, 2015 09:53 PM
ddietz97
Jul 26, 2015 06:16 PM
