G35 & G37, Coupes & Sedans
08 G35x.... Cancer maybe?
Old Mar 1, 2011 | 06:56 PM
curtiscr87's Avatar
So my g35x has 27,000 miles and i have owned for 3 month's. And this is what i get:
RUST? idk
Look Closely
Also the interior this isn't normal is it?
See where the Dash is lifting up!
Any help please? i guess i will see what the dealer has to say.
Old Mar 1, 2011 | 07:02 PM
Wannabe6MT's Avatar
-MN G Crew-
Your car is still under warranty. Get it in there and have them fix that. It should definitely not be happening, either of those things!
How often do you wash your car during the winter and do you ever wax it??
Old Mar 1, 2011 | 07:12 PM
AesonVirus's Avatar
A few guys have talked about the warping of the dash before. Luckily, I haven't had the problem. It may be caused by excessive exposure to sun and heat, something my car doesn't get too much of.
Here's a thread on the subject... hopefully there's some helpful info in there for you.
https://g35driver.com/forums/g35-sed...r-warping.html
As for the spots, start by washing and claying the car, especially that area obviously. Sometimes, what looks like rust is actually just surface corruption. If that doesn't help, get it in for warranty service if possible.
Old Mar 1, 2011 | 07:13 PM
curtiscr87's Avatar
In 3 monthes that I have had it I have washed it at least every 2 weeks and about every 3 days if its nice. It's just starting to warm up so I have not waxed it yet
Old Mar 1, 2011 | 07:59 PM
Songle6MT's Avatar
that does indeed look like a little rust. Kind of a bummer your basically new car has this issue
Old Mar 2, 2011 | 11:49 AM
Andyl's Avatar
is your car white if so white cars get those rust looking spots sometime you can take some rubbing compound and remove the stain if after the stain is removed and it still looks like rust GET 2 the dealer and have it fixed
Old Mar 2, 2011 | 11:52 AM
thescreensavers's Avatar
Mr.202?
^+1
Looks like a surface stain, claybar and/or some polish should clean it off.
Old Mar 2, 2011 | 12:17 PM
Hossmaxima's Avatar
Those rusts spots could be happening from brake dust and then slightly corrodes, claybar like everyone is saying and give it a good wax
Old Mar 2, 2011 | 01:08 PM
dylangood25's Avatar
not rust...just rail dust. claybar right off
Old Mar 2, 2011 | 01:32 PM
nismoz's Avatar
Those are not rust. I got IP too and my trunk also has those spots. I dont know why they only happen on the trunk, not anywhere else. That's weird but again that's not rust. Clay bar will help, no need to wax. If you give it a wax, that's always better.
Old Mar 2, 2011 | 03:41 PM
Wrathernaut's Avatar
Gentle Manne of Leisure
Using a decent paint cleaner (Meguiar's Fine Cut Paint Cleaner) will take the rust spots right out. Don't wax those spots until the spots are removed.
