G35 & G37, Coupes & Sedans
A/C help!
Old May 23, 2011 | 02:02 PM
luisp88's Avatar
Exclamation A/C help!
My ac takes a while to cool down, but when it does I feel like it has more potential. I recently had a new ac compressor replaced, radiator, radiator fans and heat wrapped the ac lines. Also had checked for leaks. I have black interior and painted black roof (but I really don't think that makes much of a difference)
what should I do? does the freon brand matter?
thanks,
luis.
Old May 23, 2011 | 04:51 PM
johnnydarko's Avatar
hows your condenser looking? are the blades all bent? did you make sure your refrigerant charge was at max?
also it could depend on how hot it is outside. the a/c can only cool the air so much. if its 100 degrees outside you can't expect it to cool down the air to 65
G35Rican
Jul 31, 2024 01:37 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
JLee301
Sep 25, 2015 08:46 PM
mattdg35
Sep 14, 2015 11:28 AM
