G35 & G37, Coupes & Sedans
Ultra gauge mini review
Old Aug 6, 2011 | 12:35 PM
  #31
guidoguy's Avatar
This is a good find for the price. I was running the Greddy Informeter which does less than what this device can do. The big difference was the Informeter is/was $299.
I had it installed above the A/C vent that is on the left of the cluster. I ran the wiring down the door frame rubber gasket thing over to the OBD port and you couldn't see any wires when the door was closed. The Greddy had some cool functions too but still the Ultra looks a little more comprehensive.
I sold the Greddy Informeter for school $$$ recently and have been missing all the cool data on my dash.
Thanks for finding this, gonna pick one up!
Old Aug 6, 2011 | 01:31 PM
  #32
blazeplacid's Avatar
I totally agree for the price, nothing comes close
Old Aug 6, 2011 | 02:11 PM
  #33
G35SedanGrn's Avatar
I was about to order one but it seems like it's not as great as it seems...
Old Aug 9, 2011 | 05:59 PM
  #34
mikedamageinc's Avatar
Well its no laptop that can tell you when your manifold is danger but very worth the price, looks good, compact and gives some good info that could save a trip to the tuner. You can get fuel trims O2 readings, read and clear codes and even get pending codes before the trigger the MIL. The speed can be adjusted to for tire changes or factory pm inaccuracy.
Old Nov 7, 2011 | 01:32 AM
  #35
NATH_19's Avatar
just ordered one... lol
Old Nov 7, 2011 | 02:17 AM
  #36
HenryLee's Avatar
Better than the scan gauge II?
Old Nov 7, 2011 | 08:42 AM
  #37
The Ultra gauge has more menu options and can display more info at once.
I had the Scangauge II and I just didn't like it.
Old Nov 11, 2011 | 12:30 AM
  #38
NATH_19's Avatar
I received mine today installing is easy.
Now to find a place to install it permanently.
It is kind amusing the things that is in there. I know I do not need it but it made me smile looking at the digital numbers changing and for an obii scanner its a good price.
I am a wannabe g35 that does not even have any FI of any sort with digital gauges for engine temp. air temp. sensor..etc etc.. LOL
Old Nov 11, 2011 | 12:33 AM
  #39
NATH_19's Avatar
Originally Posted by blazeplacid
After about 7 weeks of use here are my findings.
Great for uses like temperature and other things that are pulled from the ECU
Not so great for speed accuracy or if you need up to use this for up to the millisecond RPM gauge.
Over all I say its a solid piece of equipment.
You must force protocol 9141 or you may have issues as others have pointed out.
How do you force protocol 9141 ??
Old Nov 11, 2011 | 08:34 AM
  #40
menu, vehicle, force protocol
that's how it was on the classic ultra gauge
they have a newer one that will read metric units also, but I bet its the same
Old Nov 11, 2011 | 10:47 PM
  #41
NATH_19's Avatar
Got it !! I love it the screen color is perfect not bright and it blends well with my black interior.
Need to install it properly so it looks like stock...
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
