G35 & G37, Coupes & Sedans
Omg help me asap pls
Old Jul 2, 2011 | 08:02 PM
GXXXV X's Avatar
I am installing a transmission grounding wire right now and I need to know if the rubber around the wire will melt if resting against the headers/cats?
Thanks
Old Jul 2, 2011 | 10:41 PM
SxExCx's Avatar
If the wire is touching any piping, you need to re-drop it because it shouldnt make contact at all.
Old Jul 2, 2011 | 10:47 PM
GXXXV X's Avatar
I ended up just using plastic ties to hold it away from the surface of the cats and the drive shaft so its about an inch away, do you think thats okay Sean? By the way I took it for a test drive and it shifts so much smoother now! I wasn't able to get it to the screw that you showed in your picture though because i have all wheel drive and my front drive shaft is in the way.
Old Jul 2, 2011 | 10:57 PM
GeeWillikers's Avatar
Walking The Fine Line...
Sorry but OMFG I'M LMFAO @ LOL and BBQ and GTFO and YGTBFKM..
MMMkay? Bub-bye...
Old Jul 2, 2011 | 10:59 PM
GXXXV X's Avatar
ROTFL you dont make sense, and for a staff member you sure dont seem very helpful TBH
Old Jul 3, 2011 | 06:26 AM
Blue Dream's Avatar
I drove ttrank's car solo
I got what he was saying.
I'm just sayin.......................ROFLMGDMFAO
Old Jul 3, 2011 | 11:05 AM
faiz23's Avatar
I have heard few people with AWD having issues with the transmission wire. I think someone need to make a kit for AWD that has the transmission wire rerouted instead of using a generic kit for all G35. I have couple friends who are local that have the grounding kit and I will try to find a AWD and see how the wire needs to be rerouted. Until then i would look into other options or DIY and cut the wire down to perfect length instead of having to use zipties to hold it away from heat source. This should have been tested and researched during R&D even though AWD are not that common. BETTER SAFE THAN SORRY.
If anyone is looking for grounding point according to what I have seen online but have not verified it in person yet. I will be making a grounding kit for my manual vehicle even though it makes no difference just to get exact length and some quality sleeves for the wires. I prefer stealth my self and we shall see how this comes out.
1) ECU ground to grounding point on plenum near cylinder 1 (front of car passenger side)
2) PS ground to grounding point on plenum near cylinder 1 (front of car passenger side)
3) Extension from Front of timing cover to same grounding point cylinder 1 (front of car passenger side)
4) Front of timing cover (same location at #3) to Intake mounting point on plenum. (where stock z/g tube screws into plenum)
5)Intake mounting point on plenum (where stock z/g tube screws into plenum) to brake/clutch grounding point.
6) Intake mounting point to plenum grounding point on cylinder 1 (same as Step #1 & #2) (Not sure if this is necessary )
7) Front timing cover to grounding point cylinder 1 front of engine near sensor / coolant hose.
8) Grounding point to transmission
9) Intake mounting point on plenum to grounding point around driver headlight grounding point.
10) Throttle body to grounding point in battery compartment
Old Jul 3, 2011 | 12:13 PM
GXXXV X's Avatar
A bunch of kits have wires that go to the throttle bodies, would you include that as well or are those not really necessary?
Old Jul 3, 2011 | 12:24 PM
musicmob's Avatar
MMMkay? Bub-bye...
translation please..................
Old Jul 3, 2011 | 12:39 PM
GXXXV X's Avatar
MMMkay? Bub-bye...
Basically he just wrote all the text language he knows in order to be a douche cause he didn't like the title of this thread. The guy has never heard of grammar...
Translation: "Sorry but oh my ****ing god I'm laughing my ****ing *** off at laugh out loud and barbecue and get the **** out and you've got to be ****ing kidding me..."
Old Jul 3, 2011 | 12:46 PM
faiz23's Avatar
I would recommend the throttle body as well since Drive by wire works in conjunction with throttle body.
https://g35driver.com/forums/engine-...tallation.html
Old Jul 3, 2011 | 05:05 PM
gary c's Avatar
It's common sense that having any wires touching our headers/exhaust is a very bad idea....they won't survive! You could send the trans wire back telling them you need a longer wire and explain why. Zip ties should be considered a tem fix.
Gary
Old Jul 4, 2011 | 02:27 AM
walshtj's Avatar
^ +1 just redrop it behind the plastic.
jilljann1
Jul 21, 2020 08:12 AM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
_evilMonkey_
2nd Gen (V36) Sedan
Nov 22, 2015 06:21 PM
RA081024
Sep 7, 2015 01:29 AM
vashawn
Interior
Aug 6, 2015 03:26 PM
