G35 & G37, Coupes & Sedans
Test Pipes and plenum spacer saving mpg?
Old Oct 5, 2011 | 06:12 PM
LordFappington's Avatar
I removed almost everything, I saved a bunch on mpg lol. if only i could use 18s without looking stupid.
Old Oct 6, 2011 | 07:09 PM
sillyoldtayo's Avatar
i got a plenum spacer and HFC's and it definately didn't increase my mpg's. if anything i drive it harder and get worse mpg's haha
x2 on what wrathernaut said haha
Old Oct 7, 2011 | 10:52 AM
maxcoolg35's Avatar
When you say everything may I ask what everything is?
Old Oct 7, 2011 | 10:55 AM
maxcoolg35's Avatar
xet
Originally Posted by Xet
Weight will help but marginally, racing seats would hardly be worth it unless you didn't mind losing your side airbags and also wanted racing seats. Removing your spare and stuff like that could remove a decent amount of weight but then you don't have a spare on hand...
You can make minor changes to get a bit more gas mileage but you really aren't going to get much more doing weight reduction or other mods, this car simply isn't designed for that purpose. If it truly is this big of a deal to you, you may actually want to consider getting a beater car or trading cars.
Thanks I have a better insite but when you refer to minor changes what would these minor changes be?
Old Oct 7, 2011 | 11:57 AM
XiN's Avatar
XiN
Supersonic... Hypertonic
Itasha Coupe
Not this guy again...
Originally Posted by Project
Oh jeez in for the twenty follow on threads by this guy
I lost count after awhile and I don't have that thing saved on this computer anymore.
Edit: Nevermind, a simple search yielded me the list. Apparently, I missed one back in April, but no worries! I can easily add it to the ever growing list of threads.
Intake Threads:
https://g35driver.com/forums/g-spot/...lp-please.html
https://g35driver.com/forums/g-spot/...ong-order.html
https://g35driver.com/forums/g35driv...lease-cai.html
https://g35driver.com/forums/g-spot/...lease-mod.html
Exhaust Threads:
https://g35driver.com/forums/g-spot/...ld-i-pick.html
https://g35driver.com/forums/g35-cou...-help-car.html
https://g35driver.com/forums/g-spot/...st-please.html
https://g35driver.com/forums/g35-cou...er-ergent.html
https://g35driver.com/forums/g-spot/...-opinions.html
https://g35driver.com/forums/intake-...pe-2007-a.html
https://g35driver.com/forums/g-spot/...st-better.html
https://g35driver.com/forums/intake-...1-exhaust.html
https://g35driver.com/forums/g-spot/...est-pipes.html
https://g35driver.com/forums/intake-...81-m2-kcr.html
https://g35driver.com/forums/g-spot/...c-exhaust.html<-- exhaust thread from April, now added on Oct. 7th, 2011
https://g35driver.com/forums/g-spot/...aving-mpg.html<-- exhaust thread started on Oct. 2nd, 2011, added on Oct. 7th, 2011
Wheel Threads
https://g35driver.com/forums/wheels-...-oem-18-a.html
https://g35driver.com/forums/wheels-...heap-rims.html
https://g35driver.com/forums/wheels-...-oem-17-a.html
https://g35driver.com/forums/g-spot/...ercoating.html
https://g35driver.com/forums/wheels-...rged-19-a.html
Random / Misc. already discussed threads
https://g35driver.com/forums/g-spot/...se-badges.html
https://g35driver.com/forums/g-spot/...ar-please.html
Old Oct 7, 2011 | 12:50 PM
BuckeyeInMI's Avatar
I'm really not sure what the point of this entire thread is. You're not going to get good mileage with a G35 no matter what you do. If it's really that important, then buy a car that gets good mileage. But don't spend money trying to make this one more efficient, the math simply doesn't work out. As I said before, even modest changes will have minimal impact on mileage, and spending any real money means you have to drive tens of thousands of miles to recover that investment. Is it really worth owning a G35 for that long when you can't actually enjoy driving it?
Keep your car empty of non-essential items, keep your tires properly inflated, keep your windows up even in hot weather (A/C is more efficient than windows down), don't accelerate or decelerate quickly, and use cruise control on the highways.
BTW, putting 18's on your car makes it heavier, not lighter. Unless you plan on buying forged wheels, larger cast wheels weigh more than smaller ones. And no, the difference is not made up because 18" tires have less rubber in them than 17's. Metal is heavier than rubber. That's why serious drag racers here run with 15's or 16's. And if you're buying forged wheels to save money on gas, well, perhaps a basic course in economics is in order.
Old Oct 7, 2011 | 01:15 PM
High_Boost's Avatar
you could buy taller tires to change the gearing..
it would look stupid, but would lower rpm on the highway
or if you have a 6mt, you could put in the 3.3 auto diff to do the same thing
Old Oct 9, 2011 | 07:05 PM
FenixL1P's Avatar
the more aggressive the sound the car makes, the less fuel efficient the car will be. Why, cause you'll want to mash the pedal all the time. That, my friend will be the cause of less efficiency with the mods you are putting on. I've been there and i didn't even have test pipes.... just plenum and hks muffler.
JMFeld02
Intake & Exhaust
Feb 25, 2016 07:50 PM
Daniel k.
Nov 3, 2015 09:52 AM
G35VSHNG37
Oct 25, 2015 08:43 PM
Raven7
Aug 14, 2015 04:40 PM
