G35 & G37, Coupes & Sedans
Help needed!
Old Oct 14, 2011 | 07:25 PM
damdlux's Avatar
Help needed!
Hey everyone. I'm in the process of putting some 350z H-Techs on my G35 coupe. For the fronts, I pulled the struts out myself, and had the shop down the road from me change the springs over. Problem is, they put the strut plate on backwards for the passenger side. Of course by the time I was able to get to that side, the shop was already closed. Is there a way to spin the plate around without having to take it off? I don't have spring compressors, so I don't know if it's possible without them. I'm hoping I don't have to leave my car up on a jack all weekend! Thanks!
Old Oct 14, 2011 | 07:30 PM
redpearl99's Avatar
im pretty sure you have to take it off. go to napa or auto zone and borrow their spring compressor for free
Old Oct 14, 2011 | 08:07 PM
AARONHL's Avatar
You can rent spring compressors at AutoZone too. Once you have a pair of those, it's not too difficult if you can loosen the top nut.
Old Oct 14, 2011 | 08:26 PM
cameronb's Avatar
Although, even though its not advised to use air tools.. I recommend it. Its a bitch without an impact
Old Oct 15, 2011 | 05:49 AM
Blue Dream's Avatar
I drove ttrank's car solo
Not necessarily^^
Use a gooseneck 17mm wrench to put on the nut at the top of the strut, grab the flat part of the shaft with a pair of vice grips, position them 180 degrees apart, and stand on both putting force in opposite directions. I've done numerous suspension swaps and this method works every time.
Old Oct 15, 2011 | 06:53 AM
4DGS's Avatar
That's what she said
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
socalg35x
Aug 7, 2015 09:36 AM
Terry_G35
Aug 4, 2015 02:38 PM
bjo16
Aug 4, 2015 09:52 AM
newg37
Jul 26, 2015 09:32 AM
